The problems begin =(
Hello again everyone. Right now im not very happy with the problems that have just begun. It started when I bought it and the front right DRL/ low light did not turn on. Well we looked at the bulb and the one part was burned out so I bought new ones and put it in. Now the problems started: when I pressed on the brake, the front blinker light goes on! Also it seems like a short as when I turn on the blinker it cuts off the main lights too or simply does not blink at all. The bulb seemed very hot too. We are guessing its the ground. Anyone have any advice? Similar problems? Anything is appreciated! Thanks.
RE: The problems begin =(
ORIGINAL: hiwords
check all ur fuses first. it seems like there are wires that are touching each other that should not be. also wut yr and engine do u have?
ur fuses are located on the driver's side in the cabin. wait so u did find the fuses and the white pieces of paper isn't there? i believe the b5s did not come with DRL. but u can mod it to have DRL
i actually tried to take a pic of it last night but ma phone cam wont' do it even wid 2.0 megapixels.
http://www.audiworld.com/tech/elec87.shtml
that's for a 98.5 1.8t with manual trans
Alright well we checked the fuses and they seem to be fine and not burned out. Something that may not be relevant is that the top brake light is always lit when the lights are turned out. That seems to be not right..
ae u sure it's the brake light or is it the rear fogs? im not very familiar with the older tails. to tell u the truth, im not sure wut else to tell u. i hope somebody more knowledgeable would chime in. sry dude
Thanks a lot for just leading me somewhere. My car actually has the newer tails... I think I may be onto something right now but im not sure.. I think that the brake light has a 5amp fuse where a 10 is supposed to be (the brake fuse).
