Sponsored by:
Sponsored by:
Pray for Arif..
Old 02-21-2006, 05:14 PM
InsaneHatter's Avatar
Default RE: Pray for Arif..
ebc's can be flakey in wet/winter weather conditions...
but I dont really know... maybe.. why not use it if it works?
  #582
Old 02-21-2006, 05:15 PM
bc they dont work as well as an mbc. they dont stick they dont cause crazy boost spikes or surging like a mbc does. all around a ebc is the way to go when dealing with that kind of power
  #583
Old 02-21-2006, 05:20 PM
black991.8tq's Avatar
i dunno, i trust ams when it comes to evos
  #584
Old 02-21-2006, 05:52 PM
Emil@RENN=ART's Avatar
ORIGINAL: goldenchild
they've used both and have proven that it makes little to no difference.
again, if you don't know about them, read up on them.
here's a fun post about them (not too informative but still.. go to evolutionm.net for better stuff) from a while ago: https://www.audiforums.com/m_168230/tm.htm
  #585
Old 02-21-2006, 06:11 PM
onepoint8tee's Avatar
Just got off the phone with Arif, the duct tape fell off the IC, leaving a gapping hole i guess. Hes working on a "plug" for it and also trying to eliminate some exhaust rattle... He hasnt started it back up yet, but would the hole in the IC make him run rich if it wasnt plugged?
  #586
Old 02-21-2006, 06:20 PM
hmm i dont know if that would be causing the rich condition but definately the low power situation!!!
is it rich under idle or load?
  #587
Old 02-21-2006, 06:25 PM
in laymen's terms, the readings would be all off..
the maf sees a certain amount of air flow and tells the computer to send a certain amount of fuel through.. but, obviously, since the reading is too much compared to reality.. a rich condition is the result.
  #588
Old 02-21-2006, 06:29 PM
Jeff's Avatar
Zombie Defense Force
yes. your maf measures air and i it escapes then its not there but the car think it is so u run rich
  #589
Old 02-21-2006, 06:34 PM
Well ****, if hes running anything like Arif was refering to when we were getting on 315N the other day now that its plugged.. All I have to say is HOLY ****!! That thing pulled soooo hard, but it was only for a couple secs... I know that we experienced 250hp+ at that time. I was taking a video then but when the turbo spooled up it made me accidently hit the rec. button again and it killed the video. It went like this...
1. Stop light
2. Press record
3. Green light
4. Hits gas
5. I say "Holy Sh.."
6. Camera stops recording.
Too bad...
  #590
Old 02-21-2006, 06:37 PM
Jeff's Avatar
bummer get that hole fixed and see what it can do
Quick Reply: Pray for Arif..
