Sponsored by:
Sponsored by:
Pray for Arif..
Old 02-21-2006, 12:50 PM
onepoint8tee's Avatar
Default RE: Pray for Arif..
ORIGINAL: aRIf
I cannot let it go Jason, I came this close.
I was sercing other forums about my code... and something light up on my head
Q: If my DV is dead and stay open, what happens ?
Well dont you have about 2 elbow fittings on the DV? Maybe the air just isnt circulating right? I dont think it could break-that dv is beastly, but you could check it out.
  #562
Old 02-21-2006, 01:00 PM
aRIf's Avatar
This is what I have
Clearly, car was fine, till I pulled 25psi when we entering highway (Jason knows the huge pull car made when we entering 315north) then no more boost.
Something happen that huge boost and maybe DV got bad or mbc got bad no idea, something else because I still run Bill Gates Rich
  #563
Old 02-21-2006, 01:02 PM
quattrosedan's Avatar
ive had alot of problems with a mbc
Yeah, Ive had a lot of probs with them too.
  #564
Old 02-21-2006, 01:19 PM
BaconBait's Avatar
Arif- What did you use to plug the hole in the intercooler?
  #565
Old 02-21-2006, 01:22 PM
25 psi isnt going to ruin a dv. those things can handle plenty. that mbc u have, no offense, looks like a pos. ilearned that my first time when i bought a turbontics. so i went with a hallmanpro and yet i still have to crack it open and play with it so that it works right. it seems they can get stuck inside and cause all kinds of problems. there is a way to test if it is ur mbc but u need to be careful when doining it. just disconnect the line that comes from the compressor to the mbc. go drive it and let it build boost to say 15 psi and let off the gas bc if u dont that thing will make boost all the up to 35 some psi. if it does build boost then ur mbc is bad if it doesnt u have another problem. i think u should get a leak down test done if it isnt ur mbc
  #566
Old 02-21-2006, 01:25 PM
aRIf's Avatar
ORIGINAL: BaconBait
something like this
I asked the guy I need something to close a hole , he said it should do it you know the strong one. I put that one and zip tied around.
yeah I forget the check that hole, I totaly forget about it maybe the problem is that hole.
  #567
Old 02-21-2006, 01:31 PM
hahahaahahahhahhaahahahaahaha u have got to be kiddig me arif. u need something better than that MAN! u need a block off plate with a seal
  #568
That would suck if your turbo ate some duct tape! But it wouldnt make its way through the intercooler to the turbo would it??
  #569
Old 02-21-2006, 01:36 PM
no it would suck it into the engine but on a side note it wouldnt suck it it would blow it....haha that sounds funny
  #570
Old 02-21-2006, 01:38 PM
ORIGINAL: goldenchild
right.. I was backwards on the suckage.... Either way that would suck... Or blow.. Better unzip the bumper and check it out arif!
Quick Reply: Pray for Arif..
