Pray for Arif..
#491
RE: Pray for Arif..
ORIGINAL: trailboss
yea you don't need spacers for them injectors, did renn-art supply them.
nope.. that was one of the things he got on his own.
wow! missed a lot! last couple days have been nuts here!
i'm glad you got it all figured out finally! i knew the fpr wouldnt be that big of an issue... but we still include the 3bar in all packages for the B5's from now on.
i just found out from sean@unitronic that there's an update for the high boost limp mode thing. if you spike that high (25psi) with that file, it will go into limp. you can run up to around 18-19psi just fine with it, but if you want to go crazy on some race gas, or run 20-21 psi on 93/94oct, then you need the update from Unitronic... and of course, all updates are always free. if you have access to a vag com you can clear the limp quickly by just clearing codes... and set the boost a little lower until you get the update.
#494
RE: Pray for Arif..
ORIGINAL: audiboy1618
Kit sounds like a nightmare, hopefully it makes what it says it does, if so, you will be a happy man.
Arif, can you do me a huge favor and run outside and check your paint code? Im trying to find a paint code for a santorin b5.
edit:
I found this;
Santorin Blue Pearl Clearcoat LZ5K/5J
http://www.paintscratch.com/cgi-bin/makepaint2.cgi
#495
RE: Pray for Arif..
ORIGINAL: black991.8tq
can u say" i told u so"
ORIGINAL: aRIf
One think... I LOVE THE EVO DV SOUND... That's perfectly what I like...
Thanks a lot black991.8tq
#496
RE: Pray for Arif..
ORIGINAL: 2871relimB5A4
how do you get the updated file? i just got my software today, so im sure i have the most recent file. do nDBWs hit limp mode? i thought the ndbws didnt do that......
#497
RE: Pray for Arif..
Before I went to garage today (to clean everthing) I drove the car about 5 mins. Check Engine Light came on and park it asap and check the code. Code was 300,301,302 (or something like that) says that multiple missfire, cylindern 1 and 3 missfired.
I am using NGK BKR6E .029 gapped.
Should I use different plugs or what ? Any one can help me ?
Thanks
Thanks
