Pray for Arif..
#43
RE: Pray for Arif..
ORIGINAL: goldenchild
did u get it started?
I dont know that he can get to the bottom manifold bolts to losen without unbolting the turbo from the manifold/cat? What do you think? Im gunna try to get over there tonight to help with the brakes.
#47
RE: Pray for Arif..
ORIGINAL: aRIf
renn-art;
Do I need to easy on this turbo first 500miles ?
renn-art;
actually, if you installed it correctly, no.. but it's still a good idea to be careful while it's just installed, to make sure everything is solid. if you feel confident, however, go for it!
make sure you set the boost at a safe level to start with (15psi)... and we wouldn't recommend going much over 20psi on pump gas (always log if you do).
#49
RE: Pray for Arif..
I just talked to Arif.. He is about to instal the DV, he got the all the manifold bolts on, without having to unbolt the turbo..
So, the software for his ecu is for race gas?? I dont know if he knew that, if thats what you are trying to say?
#50
RE: Pray for Arif..
no they arent sayin that. they are saying he needs to set boost accordinly to what octane he is goin to run. they are saying that he should only run a max of 20 psi on 93 octane. if u want to increase the boost then u will need to run 100 octane. if he doesnt have that mbc he is probally only goin to get 7 psi if that of boost bc my guess unitronics wrote that file to be used with a mbc and not even have the n75 hooked up but just electrically hooked up.
