Sponsored by:
Sponsored by:
Pray for Arif..
Old 02-19-2006, 01:57 AM
Jeff's Avatar
Zombie Defense Force
Default RE: Pray for Arif..
not in the engien just one the vac lines and the ic piping, if there is a leak in the lines it will cause the soapy water to bubble and then u will see it
  #482
its okey as long as you put it on pipes with boost. There is another test with a lighted match, however its a bit more dangerouse couse you mightg have a fuel leak.
Oh there is another test with the things that doctors use to listen for lungs in thee patience. I did it and found that couple of my lifters are bad. anywho you will need to listen for sounds.
  #483
Old 02-19-2006, 01:59 AM
Jeff's Avatar
o **** i just realized i put in the pipes i meant on the pipes dont put them in my bad osrry bout that
  #484
Old 02-19-2006, 02:19 AM
dude that was the first thing i questioned about that kit when we were putting it in. crazy.....
  #485
Old 02-19-2006, 02:20 AM
o ya try disconnecting the ecu for a few min and see if u get boost back. u shouldnt be in limp mode if the n75 isnt hooked up
  #486
Old 02-19-2006, 02:41 AM
aRIf's Avatar
ORIGINAL: goldenchild
yeah I remembered bro, that's why I wanted to check it second time.
  #487
Old 02-19-2006, 03:12 AM
audiboy1618's Avatar
Kit sounds like a nightmare, hopefully it makes what it says it does, if so, you will be a happy man.
Arif, can you do me a huge favor and run outside and check your paint code? Im trying to find a paint code for a santorin b5.
  #488
Old 02-19-2006, 03:52 AM
2871relimB5A4's Avatar
im almost have the turbo in. the oil return line is a bitch, but i figured it out. i just gotta tighten it down tomorrow and put all hoses in along with injectors, oil, coolant, and etc. the oil line slowed me down a lot. took at least 2 hours to get it on. you have to do it perfectly or else you cant get it on.
anyways, glad to hear you got it running. BTW, i thought you were a 98. 98 doesnt have limp mode. well i will be done tomorrow. i actually am probably gonna stay up tonight and work on it. im really excited. BTW, did your MAF sensor from you stock maf fit with your new MAF housing? i have the wrong MAF housing, but i was gonna rig it together. however, the hole that the sensor goes in wont fit by almost a 1/4 ". im just gonna get a diff maf housing tomorrow.
  #489
Old 02-19-2006, 03:54 AM
black991.8tq's Avatar
ORIGINAL: aRIf
One think... I LOVE THE EVO DV SOUND... That's perfectly what I like...
can u say" i told u so"
  #490
Old 02-19-2006, 03:58 AM
trailboss's Avatar
ORIGINAL: aRIf
I dont think that I have boost leak but just wanna know for incase. Maybe just running in limp mode because I passed 25psi ones.
kakarot: what is foam check ?
mine is similar to this, its good to have. I used a tire vlave stem and pulled it through the PVC endcap and siliconed it in. Boost leak
Quick Reply: Pray for Arif..
