Power windows malfunction on 02 A4
Hi, the power windows in my 2002 A4 1.8T malfunctions. But of course the difficult part is that it doesn't happen always. It happens more often than it doesn't but still the mechanics at the dealership said they didn't see anything wrong!
The window switches have a 2-step function - pressed half-way i.e. 1 click they raise or lower normally but pressed all the way down (or up) they raise or lower the window all the way i.e. 'auto' mode. That doesn't seem to work always. Sometimes pressing them down makes them go up!! Or sometimes they don't respond at all.
Anyone else see this problem?? I am convinced it is not a mechanical issue because this problem is there for all the 4 windows. I have VAG-COM so if someone has tried resetting to fix this problem let me know. Going to the dealership seems useless!
Thanks
Thanks
RE: Power windows malfunction on 02 A4
it's the switch, i had the same problem with mine, you roll them down and they go back up, or roll them up and it would go back down about 2" and would be stuck there for about five minutes, took it to the dealer and they didn't find anything wrong but they replaced all switches anyways. call the 800 audi # if they won't replace them.
brettmichaelsmith
04-07-2014 11:00 PM
