Power Steering Pump Noise!!??
Anyone that had a noisy power steering pump?? Especially when its cold, its humming like a buzzbomb. I thought of changing the fluid? will that help or should I go for a new pump?
RE: Power Steering Pump Noise!!??
Probably low fluid which probably also means you have a leak somewhere. Mine did that and I topped it off and then it started again a month later so I knew it was a leak. Ended up being just a hose coming out of the resevior. Although, it did cost $65 from the dealership!
got the same prob. excpet mine loses power at low rpms.... feels like manual steering
I'm thinkin of just pulling it and runnin full manual steering [8D]
is it just me or are those d*mn sponsered links HELLA annoying
when its cold out mine usualy makes that noise. it also makes that noise when it low i an losing fluid through multiable lines. dont feel like replaceing them so i just keep adding oem fluid when it gets low.
pwonder
05-03-2009 01:45 PM
