power steering
power steering
ok i need help with this power steering it is making that winding niose and when i checked it the fluid is full but its foam looking like there is air it in. i need to know if there is a way to drain this pump so i can fill it up again to make sure its dead of not thank alot
RE: power steering
The easiest way is to remove the drain lines from under the reservoir. Replenish the tank with fresh Pentosin 11s, drive for a few days and repeat once again. That should flush out most of the system. It wasn't filled with non pentosin fluid recently was it?
kobe24
05-01-2009 12:17 PM
ZaZapp
04-30-2007 03:18 PM
