Sponsored by:
Sponsored by:
PING PING!!
Old 12-14-2004, 05:51 PM
Soley4pres's Avatar
Default PING PING!!
And Im not talkin golf clubs...lol
I just did a tune up 2 weeks ago...new plugs and new filters...my car ran great up until this weekend...when it starts it sounds kinda funny like a pingy sound...it goes away after a min...but then I can here it when the car accelerates some...it just kinda sounds loud...
it shifts smooth through all gears but I think I notice a power loss...
help guys...please...
thanks yall
T odd
Old 12-14-2004, 05:55 PM
Daytona A4QV6's Avatar
Default RE: PING PING!!
bad gas????
Old 12-14-2004, 07:03 PM
SlimChriz's Avatar
did you gap the plugs?...
Old 12-14-2004, 07:07 PM
J.James's Avatar
I'm not sure on the newer cars but check your "knock sensor," these are designed to keep the combusting gas from burning too hot. The other reply, about bad gas could also be on the right path, lower octane fuel also can cause this problem
Old 12-14-2004, 07:08 PM
audiboy1618's Avatar
Run a tank of 94oct through it.
Old 12-15-2004, 12:06 AM
david9999's Avatar
? wrong temp plugs?
Old 12-15-2004, 12:12 AM
your just detonating its no big del since this hasnt been going on for long tie. removr your plugs nd check the gap. double check every thing you did.
Old 12-15-2004, 01:46 AM
zachd's Avatar
Detonation no big deal hehehe what book was this learned from!
Old 12-15-2004, 02:07 AM
mikehh's Avatar
Go with David. I don't know where you got the plugs, but ALWAYS check for the right temp plug. If the don't conduct enough heat to the head, the plug will get hot and will cause pre-ignition. NO GOOD!!
Old 12-15-2004, 03:27 AM
SlimChriz's Avatar
ORIGINAL: SlimChriz
or go with what slimchriz said
What dave is sayin is that its only been happening for short period of time so if he takes care of it itll be fine.. yes detonation will cause damage over time
Quick Reply: PING PING!!
