Passengers lights. Needs a flash light
Hello Gang,
I was wondering if someone here, has experienced the same delima. For some reason, upon mighty graces that happens to annoy the heck out of me.
1) The back passenger dome lights does not work, and if it does work, it's as dim, as a firefly's ***, and when the off and on button it's pressed on or off, the darn thing stays off.
2) Also there should be a red illumination, lighting a symbol of a light, that too is also off.
3) The front is okay, it illuminates when the door is opened and the driver, as well, as the passenger's optional lights turns off and on without any problems
So, anyone can shed a light or a guidance to how I might solve this mystery of a brown-out back passengers light?
Thanks in advance.[/align]
RE: Passengers lights. Needs a flash light
Tech is right, t'was the door switches, as I am told by the dealer who worked on it. When I was at the dealers it worked, I was turning it on and off. I turned if off. They where closing, and the rep. that helped me out was gone for the day. Earlier today, when I got home. I tested it out. NO FREAK'n lights This is starting to annoy me.
Can I claim this a lemon In any rate....
Question for you Tech. Where is the door switches located?
slowmo
05-22-2007 06:29 PM
