painting my lowers ... supplies? / PAINT CODES??
RE: painting my lowers ... supplies?
ORIGINAL: ironman
I would paint the Audi Rings White, Bright white for that matter, red and white looks real sweet together i bet it would look insane, X1 think about i think it will set the car off really nice.
Cool man, nice work.. how did you take the pieces off?
For the front bumper, you need to peel the wheel well lining to access the six 10mm nuts (three each side) inside the fender.
Then remove the corner grills to access the long bolts on each side.
...and finally, bumper attachment to guide piece...
Here is a summary of all the front bumper attachment points (circled in the pic).
For the rear bumper, you have to remove the black bumper trim (2 nuts).
Make sure you disconnect the light before taking it off.
Then you need to peel the trunk liner.
And then you can access the 10mm nuts inside the fender on each side.
Last step before removal is to unscrew the underside of the bumper (easily seen by lying down under the rear bumper).
For the side lowers, remove the trim strip on the top side and you will see a bunch of torx screws all along the running board.
There also some torx screws underneath the running boards, and look for some more in the rear and front wheel wells (alsoin the carpet-like noise insulation).
The easiest one is the doorblade, just 2 screws per doorblade on the inside of the door.
Hope this helps!
ORIGINAL: theguy1084
I just talked to a good body shop that my VW dealer takes thier cars too. It was going to be about $1200
x1, I don't think your FMIC is big enough! Hella good job on the lowers, looks really good. Just goes to show that you don't need to spend the $1200 and you can do it yourself!
ORIGINAL: cyberlogicx
The FMIC took me about 20 hrs to process. I wasn't happy with the stock finish, the cast marks were huge. I sanded, polished and buffed it for a while and turned it from this:
to this:
#19
RE: painting my lowers ... supplies? Paint codes...
Hey, so Im actually having a lot of trouble finding my color match. Turns out my silver 1999 color is different from even the 2000 or 2001 silvers, or at least the name was changed.
Mine is LY7M "Aluminum Silver Metallic" whereas the 2000/2001 is LY7W "Light Silver Metallic"
Anyone have any good websites for ordering spray paint??? Or do you think Light silver metallic will look the same?
