Sponsored by:
Sponsored by:
overheat oil !!!
Old 01-03-2007, 11:17 PM
sautsinaga's Avatar
Default overheat oil !!!
Hi all,
I have a 1996 A4 Quattro.
I just recently added some G12 engine coolant into the reservoir.
I drove around for about 1 hour or so until I realized that the temperature indicator for the oil is over 350F, which is overheated. (Ps: not the engine temperature indicator)
then I checked the engine coolant reservoir and I realized that I fill it up over the max point, so I drained some off.
It was fine for a little bit, but when I started driving the car again, it only took about 15 minutes for the oil temperature indicator reaches 350F (overheat).
Do you know whats wrong with it?!?!?!?!??!?!?!?!!!!
HELP please....
Old 01-03-2007, 11:24 PM
BadLuckAudi's Avatar
Default RE: overheat oil !!!
does it have oil???
Old 01-03-2007, 11:29 PM
sautsinaga's Avatar
yes, the oil is still full....
Old 01-03-2007, 11:46 PM
SMoLiK's Avatar
This may sound dumb but where did you put the coolant exactly... The big semi clear tank above the engine or the lid just above the front right of the engine...
SMo'
Old 01-03-2007, 11:50 PM
sautsinaga's Avatar
the clear tank one...
Old 01-03-2007, 11:56 PM
SMoLiK's Avatar
What was the purpose of adding more coolant? How was the car acting previous to this, let us in on some more info about the car prior to you putting more coolant in.
SMo'
Old 01-04-2007, 12:04 AM
dankhound's Avatar
I would have to say the more likely cause was a glitch in the sensor itself versus a high oil temperature. You have to drive with no oil, or at top speed for like 20 min for the oil temp to actually get that high.
Old 01-04-2007, 12:06 AM
sautsinaga's Avatar
the water coolant level was a little below the min level and it made my temperature light to go off every 30 min or so. Thats why i decided to add some coolant in to fix the problem.
However, before I added the new coolant in the car was running fine.
Btw, I only use the G12 pentossin for my engine coolant.
Old 01-04-2007, 12:17 AM
Godfather #90's Avatar
i flushed my coolent system when i changed my timing belt, and i got the system airlocked and it ran mad hot untill it bled its self, i wouldnt run it untill u know its getting the coolent. squeeze the tube coming from the head of the motor and see if u can see it squirt into the tank. if it doesnt, then its airlocked like mine was. it is the big black tube that goes into the front of the tank btw.... dont know what its realy called. hope this helps a little bit...
Old 01-04-2007, 02:13 AM
sautsinaga's Avatar
so, if it is airlocked, does that mean i have to flush it down and refill it?
in the mean time, is there any other ideas on how to fix the problem?
Quick Reply: overheat oil !!!
