Sponsored by:
Sponsored by:
Ok time to get to the bottom of this!(Added VAG log)
Old 02-24-2007, 11:31 PM
spud's Avatar
Default RE: Ok time to get to the bottom of this!
Well keep this thread updated if you find a cure. I'm in the same boat as you. I have a 1998.5 2.8L quattro. I do not havea great idea of what my MPG would be normally, but I am in a city for the school year and it dropped way way down. I just did my airfilter, so we'll see if that helps.... but let me know if you find anything new. Thanks.
  #22
Old 02-24-2007, 11:44 PM
Turbulence's Avatar
ORIGINAL: alias747
The wheels and tires have only been on there for maybe 2 tanks of gas. I have been getting this crappy mileage for like 3 months or more now.
How do find the long term fuel trim? And MAF?
Oh yeah, and when I changed my air fiilter, I took my MAF out and it looked flawless, not dirty at all...
you may still want to pick up some electronics cleaner and clean the MAF... mine was throwing a CEL and when I took it out it looked fine, but i guess it was dirty since my CEL turned off after cleaning, just a thought.
  #23
Old 02-25-2007, 01:58 PM
david9999's Avatar
Oxygen sensors die a slow death, and it isn't until they are pretty much dead that they will flash a CEL. The standard fuel trim at idle should be close to zero. Excursions +/-10% are allowed before tripping a CEL.
Agree, oxygenated fuel and cold winter weather will drop about 3 mpg off your fuel efficiency.
Some of these have probably been suggested but I didn't closely review the whole thread.
1. Did you gap your spark plugs correctly? or did the problem antedate changing them.
2. Clogged fuel filter causes lean condition, not rich condition, so it is highly unlikely as a cause.
Didn't see whether the problem was beofre or after you changed wheels. If the OD is larger than standard your odometer will be off. Grab a friend and drive in two cars the same distance and see if there is a big difference in the trip odometer reading between the cars, or if you live in an area with highway mileage markers, use them to check your trip odometer.
  #24
Old 02-25-2007, 02:55 PM
alias747's Avatar
ORIGINAL: david9999
I know it is not the wheels. My mileage went down like 1/4 mpg after I put my new wheels on, that is just from them throwing the trip odometer off I am sure. So now when I fill up i get like 19.8 miles to the gallon consistently. I used to get like 20.1, thats just from the diameter change in the wheels I am sure. SO EVERYONE CAN STOP SAYING IT'S THE WHEELS!
The sparks and the air filter didn't seem to make a difference in the MPG, 20 before, 20 after.
It's when it went from 27-28 on the first few tanks I had it, to 20-21 is when I realized something must be wrong. But I def. think i am running rich, starting my car this morning, I could almost smell a pure gas smell. And it usually smells real strong. So once I understand how to log the MAF and the O2 sensors I will see what is up and post back. Thanks for all the suggestions!
  #25
Old 02-25-2007, 03:05 PM
[IMG]local://upfiles/12092/1A0ECC49EF0840AD9D6297E5DAB09FF2.jpg[/IMG]
  #26
Old 02-27-2007, 03:06 PM
alias747's Avatar
Ok well I ran a log in VAG on blocks 003 and 031 as the link Wolfdog told me to do, then did a redline in 3rd gear with full throttle. Well block 31 doesn't seem liek it was the right one because it was supposed to be the O2 sensors I think and it was telling me the voltage of something... Anyway, I think that the 003 was right it was giving me g/s. The log is really confusing to read though. I will copy and paste it hear and see if someone can decifer it, but it looks like my MAF is giving irregular readings, possibly...
Tuesday,27,February,2007,10:32:21
8D0 907 559 C ,,1.8L R4/5VT MOTR AT D01,
,Group A:,'003,,,,Group B:,'031,,,,Group C:, Not Running
,,RPM,Mass Flow,T.B. Angle,Ign. Timing,,Voltage,Voltage, , ,,,,,
,TIME,,,,,TIME,,,,,TIME,,,,
MARKER,STAMP, /min, g/s,°, °ATDC,STAMP, V, V,,,STAMP,,,,
,0.50,880,6.04,6.9,12.0,0.87,0.695,0.440, , ,,,,,
,1.25,880,6.18,6.9,12.0,1.62,0.195,0.440, , ,,,,,
,2.01,840,6.04,6.9,12.0,2.39,0.040,0.440, , ,,,,,
,2.76,880,6.18,6.9,12.0,3.14,0.690,0.440, , ,,,,,
,3.51,880,6.11,6.9,12.0,3.89,0.355,0.440, , ,,,,,
,4.26,840,6.11,6.9,12.0,4.65,0.040,0.440, , ,,,,,
,5.01,1200,11.87,15.2,14.3,5.40,0.765,0.440, , ,,,,,
,5.78,1400,15.21,19.1,13.5,6.15,0.045,0.440, , ,,,,,
,6.53,1480,16.81,20.0,13.5,6.90,0.030,0.425, , ,,,,,
,7.29,1560,17.29,20.0,14.3,7.65,0.090,0.425, , ,,,,,
,8.04,1680,17.92,20.0,15.8,8.40,0.715,0.425, , ,,,,,
,8.79,1840,18.75,20.0,15.8,9.16,0.045,0.425, , ,,,,,
,9.54,2200,33.47,31.7,14.3,9.92,0.800,0.440, , ,,,,,
,10.29,2720,47.08,33.9,17.3,10.68,0.020,0.425, , ,,,,,
,11.04,3160,53.75,33.9,21.0,11.43,0.705,0.425, , ,,,,,
,11.81,2320,39.72,33.4,14.3,12.20,0.500,0.425, , ,,,,,
,12.60,2440,37.92,27.3,17.3,12.98,0.015,0.440, , ,,,,,
,13.38,2360,23.75,20.8,21.0,13.75,0.795,0.425, , ,,,,,
,14.13,2160,11.04,12.2,25.5,14.50,0.835,0.460, , ,,,,,
,14.87,2000,11.46,13.0,24.8,15.25,0.010,0.460, , ,,,,,
,15.62,1840,27.78,33.9,6.0,16.00,0.705,0.460, , ,,,,,
,16.37,2280,46.53,80.7,10.5,16.76,0.805,0.460, , ,,,,,
,17.12,2600,56.94,82.5,12.8,17.51,0.790,0.460, , ,,,,,
,17.88,2680,58.26,82.0,13.5,18.26,0.780,0.460, , ,,,,,
,18.64,2720,60.48,83.3,13.5,19.03,0.790,0.460, , ,,,,,
,19.41,2840,64.09,83.3,13.5,19.78,0.785,0.460, , ,,,,,
,20.15,2960,68.40,82.9,14.3,20.51,0.790,0.460, , ,,,,,
,20.90,3080,71.67,82.9,15.8,21.28,0.805,0.480, , ,,,,,
,21.67,3200,73.26,82.9,17.3,22.05,0.790,0.480, , ,,,,,
,22.42,3360,76.46,82.9,19.5,22.82,0.810,0.480, , ,,,,,
,23.19,3520,78.47,82.5,21.8,23.59,0.820,0.480, , ,,,,,
,23.97,3680,81.59,82.5,22.5,24.34,0.820,0.480, , ,,,,,
,24.72,3800,85.14,79.4,23.3,25.09,0.820,0.480, , ,,,,,
,25.47,3920,88.26,76.4,24.0,25.87,0.820,0.500, , ,,,,,
,26.27,4080,89.72,72.9,25.5,26.64,0.820,0.500, , ,,,,,
,27.03,4200,92.08,69.9,26.3,27.41,0.820,0.500, , ,,,,,
,27.78,4320,91.73,62.1,27.0,28.16,0.820,0.515, , ,,,,,
,28.56,4400,88.47,55.1,27.8,28.95,0.825,0.515, , ,,,,,
,29.31,4520,89.93,55.6,28.5,29.70,0.825,0.515, , ,,,,,
,30.08,4600,92.92,55.6,28.5,30.45,0.825,0.535, , ,,,,,
,30.83,4720,95.69,56.0,28.5,31.20,0.825,0.535, , ,,,,,
,31.59,4800,97.36,56.0,28.5,31.95,0.825,0.555, , ,,,,,
,32.34,4840,94.31,46.0,29.3,32.74,0.875,0.575, , ,,,,,
,33.12,4400,12.98,12.6,37.5,33.52,0.860,0.590, , ,,,,,
,33.89,4080,9.09,10.0,37.5,34.29,0.000,0.590, , ,,,,,
,34.66,3760,7.92,8.7,37.5,35.04,0.000,0.330, , ,,,,,
,35.42,3440,7.22,7.8,36.8,35.81,0.000,0.275, , ,,,,,
,36.19,3120,6.32,6.9,34.5,36.58,0.000,0.255, , ,,,,,
,36.96,2840,5.76,6.1,32.3,37.34,0.000,0.235, , ,,,,,
,37.73,2600,5.14,5.2,30.0,38.11,0.000,0.215, , ,,,,,
,38.50,2440,4.44,4.3,29.3,38.90,0.000,0.200, , ,,,,,
,39.26,2320,4.51,4.3,28.5,39.65,0.000,0.200, , ,,,,,
,40.02,2240,4.31,4.3,27.8,40.38,0.000,0.180, , ,,,,,
,40.78,2080,4.09,3.9,27.0,41.17,0.000,0.180, , ,,,,,
,41.57,1960,3.89,3.5,26.3,41.94,0.000,0.180, , ,,,,,
,42.32,1800,3.89,3.5,25.5,42.70,0.000,0.160, , ,,,,,
,43.09,1640,3.89,3.9,24.8,43.49,0.000,0.160, , ,,,,,
,43.86,1440,3.82,3.5,23.3,44.24,0.000,0.140, , ,,,,,
,44.61,1240,3.82,3.9,7.5,44.99,0.020,0.140, , ,,,,,
,45.36,1280,4.03,3.9,12.8,45.74,0.090,0.125, , ,,,,,
,46.11,1240,4.23,4.3,18.0,46.49,0.795,0.125, , ,,,,,
,46.89,1120,4.44,5.2,15.0,47.28,0.590,0.105, , ,,,,,
,47.66,1000,4.79,5.2,12.0,48.03,0.725,0.105, , ,,,,,
,48.41,1000,5.21,5.6,12.0,48.81,0.780,0.105, , ,,,,,
,49.21,1000,5.28,6.1,12.0,49.60,0.085,0.105, , ,,,,,
,49.97,920,5.21,5.6,12.0,50.35,0.765,0.105, , ,,,,,
,50.73,920,5.07,5.6,12.0,51.12,0.700,0.105, , ,,,,,
,51.49,840,5.07,5.6,12.0,51.87,0.310,0.105, , ,,,,,
,52.25,800,5.07,5.6,15.0,52.64,0.735,0.105, , ,,,,,
,53.02,800,5.14,6.1,15.0,53.39,0.095,0.125, , ,,,,,
,53.77,1120,8.75,10.4,19.5,54.16,0.745,0.125, , ,,,,,
,54.56,960,5.76,6.9,12.0,54.94,0.085,0.125, , ,,,,,
,55.33,880,5.48,6.5,5.3,55.71,0.760,0.125, , ,,,,,
,56.08,880,5.56,6.1,8.3,56.46,0.100,0.140, , ,,,,,
,56.83,840,5.56,6.1,6.0,57.21,0.200,0.140, , ,,,,,
,57.60,800,5.21,6.5,15.0,58.00,0.235,0.140, , ,,,,,
,58.38,880,5.83,6.9,6.8,58.75,0.730,0.160, , ,,,,,
,59.15,1000,8.06,9.5,18.8,59.52,0.640,0.255, , ,,,,,
,59.90,1120,8.68,10.4,22.5,60.28,0.080,0.610, , ,,,,,
,61.68,880,5.42,6.1,12.0,62.06,0.585,0.760, , ,,,,,
,62.44,840,5.48,6.5,12.0,62.81,0.645,0.760, , ,,,,,
,63.20,840,5.14,6.1,5.3,63.56,0.125,0.760, , ,,,,,
,63.93,840,5.42,6.1,9.0,64.32,0.740,0.760, , ,,,,,
,64.68,840,5.48,6.1,9.0,65.07,0.100,0.760, , ,,,,,
,65.44,840,5.42,6.5,11.3,65.82,0.080,0.760, , ,,,,,
,66.19,1000,7.78,10.4,18.8,66.57,0.785,0.760, , ,,,,,
,66.94,1200,9.86,12.6,22.5,67.32,0.665,0.780, , ,,,,,
,67.72,1320,11.73,14.8,22.5,68.11,0.065,0.760, , ,,,,,
,68.49,1440,12.78,15.6,23.3,68.87,0.130,0.760, , ,,,,,
,69.26,1840,23.47,24.3,19.5,69.63,0.095,0.745, , ,,,,,
,70.01,2120,27.84,24.7,20.3,70.39,0.595,0.725, , ,,,,,
,70.78,2480,31.25,25.2,24.0,71.16,0.205,0.705, , ,,,,,
,71.55,2880,39.72,28.2,24.0,71.93,0.705,0.705, , ,,,,,
,72.30,3280,47.57,30.4,26.3,72.68,0.785,0.480, , ,,,,,
,73.07,2400,38.33,30.4,18.0,73.43,0.235,0.610, , ,,,,,
,73.83,2240,36.87,32.1,16.5,74.20,0.735,0.650, , ,,,,,
,74.59,2440,51.18,82.0,12.8,74.95,0.770,0.800, , ,,,,,
,75.32,2640,57.29,85.5,13.5,75.69,0.765,0.800, , ,,,,,
,76.07,2440,52.84,85.5,12.0,76.46,0.725,0.780, , ,,,,,
,76.83,2480,55.07,87.7,12.0,77.21,0.725,0.760, , ,,,,,
,77.59,2560,57.15,87.7,12.8,77.98,0.695,0.760, , ,,,,,
,78.35,2640,59.37,87.7,12.8,78.71,0.755,0.780, , ,,,,,
,79.10,2680,60.90,87.7,12.8,79.47,0.745,0.800, , ,,,,,
,79.85,2720,63.06,87.7,12.8,80.22,0.780,0.800, , ,,,,,
,80.60,2760,64.79,87.7,12.8,80.98,0.780,0.820, , ,,,,,
,81.37,2800,64.72,87.7,13.5,81.74,0.780,0.820, , ,,,,,
,82.12,2800,65.90,87.7,13.5,82.50,0.785,0.820, , ,,,,,
,82.87,2880,66.73,87.7,13.5,83.27,0.775,0.820, , ,,,,,
,83.64,2880,67.64,87.2,13.5,84.02,0.790,0.820, , ,,,,,
,84.39,2920,67.71,87.2,14.3,84.79,0.775,0.820, , ,,,,,
,85.19,2960,68.75,86.4,14.3,85.56,0.775,0.820, , ,,,,,
,85.96,2960,68.89,85.9,14.3,86.34,0.780,0.800, , ,,,,,
,86.73,3040,70.48,85.5,15.0,87.10,0.765,0.800, , ,,,,,
,87.48,3080,71.32,84.6,15.8,87.86,0.760,0.800, , ,,,,,
,88.23,3120,72.78,83.3,15.8,88.63,0.775,0.800, , ,,,,,
,89.02,3200,73.12,80.7,17.3,89.40,0.770,0.800, , ,,,,,
,89.77,3240,74.44,79.4,18.0,90.15,0.760,0.800, , ,,,,,
,90.54,3320,75.48,78.6,18.8,90.90,0.775,0.800, , ,,,,,
,91.29,3360,76.59,78.1,19.5,91.67,0.780,0.800, , ,,,,,
,92.06,3440,76.87,74.6,20.3,92.42,0.770,0.800, , ,,,,,
,92.81,3480,73.82,61.2,21.0,93.19,0.775,0.800, , ,,,,,
,93.57,3480,67.71,39.9,22.5,93.96,0.755,0.780, , ,,,,,
,94.34,3040,15.42,15.6,36.8,94.73,0.730,0.820, , ,,,,,
,95.09,2840,6.04,6.1,32.3,95.48,0.550,0.835, , ,,,,,
,95.85,2640,4.58,4.3,30.8,96.23,0.010,0.820, , ,,,,,
,96.61,2520,4.23,3.9,30.0,97.00,0.005,0.010, , ,,,,,
,97.38,2320,4.17,3.9,28.5,97.75,0.000,0.010, , ,,,,,
,98.13,2120,3.82,3.5,27.0,98.50,0.000,0.010, , ,,,,,
,98.87,1920,3.47,3.0,26.3,99.24,0.000,0.000, , ,,,,,
,99.62,1720,3.06,2.6,24.8,100.01,0.000,0.000, , ,,,,,
,100.39,1520,2.57,1.7,24.0,100.77,0.000,0.000, , ,,,,,
,101.14,1360,2.29,1.3,21.0,101.53,0.000,0.000, , ,,,,,
,101.89,1280,3.61,6.1,19.5,102.28,0.695,0.010, , ,,,,,
,102.66,1880,17.50,20.4,19.5,103.03,0.080,0.085, , ,,,,,
,103.45,2000,22.57,22.6,24.0,103.81,0.355,0.105, , ,,,,,
,104.20,2040,24.86,23.4,22.5,104.58,0.375,0.125, , ,,,,,
,104.95,2080,26.11,23.4,21.8,105.33,0.600,0.140, , ,,,,,
,105.70,2080,26.32,23.0,21.8,106.08,0.740,0.160, , ,,,,,
,106.48,1560,4.37,4.3,21.8,106.87,0.890,0.160, , ,,,,,
,107.25,1480,4.44,4.8,21.8,107.62,0.845,0.855, , ,,,,,
,108.00,1440,4.72,4.8,21.0,108.39,0.800,0.875, , ,,,,,
,108.77,1400,4.93,5.2,21.0,109.16,0.625,0.855, , ,,,,,
,109.54,1320,4.93,5.2,21.0,109.94,0.060,0.835, , ,,,,,
,110.31,1320,4.93,5.2,21.0,110.69,0.085,0.820, , ,,,,,
,111.06,1280,4.93,5.2,21.0,111.44,0.690,0.800, , ,,,,,
,111.83,1240,3.68,2.6,19.5,112.21,0.755,0.780, , ,,,,,
,112.58,1040,3.12,2.6,12.8,112.96,0.075,0.780, , ,,,,,
,113.33,1000,3.19,2.6,12.0,113.70,0.125,0.760, , ,,,,,
,114.08,1000,3.33,3.0,12.0,114.45,0.585,0.760, , ,,,,,
,114.84,960,3.40,3.5,12.0,115.22,0.070,0.760, , ,,,,,
,143.73,2160,17.98,18.7,31.5,144.13,0.120,0.630, , ,,,,,
,144.51,2200,19.37,19.5,30.0,144.88,0.700,0.630, , ,,,,,
,145.26,2320,32.36,28.6,21.0,145.65,0.730,0.630, , ,,,,,
,146.01,2480,40.83,32.1,18.8,146.40,0.115,0.630, , ,,,,,
,146.77,2800,45.90,32.5,20.3,147.15,0.720,0.610, , ,,,,,
,147.55,3000,16.18,15.2,36.8,147.93,0.780,0.610, , ,,,,,
,148.30,3040,14.44,15.2,33.8,148.69,0.100,0.745, , ,,,,,
,149.09,2640,12.15,13.5,32.3,149.47,0.060,0.745, , ,,,,,
,149.85,2240,13.47,17.4,34.5,150.22,0.745,0.725, , ,,,,,
,150.62,2280,44.72,87.7,12.8,151.02,0.765,0.745, , ,,,,,
,151.41,2480,53.68,76.8,12.8,151.79,0.680,0.760, , ,,,,,
,152.16,2680,57.92,76.8,13.5,152.54,0.675,0.725, , ,,,,,
,152.91,2880,64.03,76.8,14.3,153.29,0.745,0.745, , ,,,,,
,153.66,3080,69.44,76.4,15.8,154.06,0.745,0.745, , ,,,,,
,154.44,3280,73.33,76.0,18.8,154.83,0.760,0.760, , ,,,,,
,155.21,3480,76.11,75.5,21.8,155.58,0.770,0.780, , ,,,,,
,155.96,3680,79.58,75.1,23.3,156.35,0.775,0.780, , ,,,,,
,156.72,3880,85.21,75.1,24.0,157.12,0.775,0.780, , ,,,,,
,157.50,4040,89.37,74.6,24.8,157.88,0.785,0.780, , ,,,,,
,158.25,4240,93.82,75.5,25.5,158.64,0.790,0.800, , ,,,,,
,159.02,4400,96.32,75.1,27.0,159.40,0.785,0.800, , ,,,,,
,159.79,4560,100.56,74.6,27.0,160.16,0.795,0.800, , ,,,,,
,160.54,4720,103.75,73.8,27.0,160.91,0.805,0.800, , ,,,,,
,161.29,4880,107.08,72.9,27.0,161.66,0.815,0.820, , ,,,,,
,162.04,5000,109.09,67.7,27.0,162.43,0.810,0.820, , ,,,,,
,162.80,5120,107.92,65.5,27.8,163.18,0.810,0.820, , ,,,,,
,163.55,5240,109.37,64.7,27.8,163.93,0.815,0.820, , ,,,,,
,164.30,5360,111.04,64.7,27.8,164.68,0.815,0.820, , ,,,,,
,165.05,5480,111.46,62.5,28.5,165.43,0.815,0.820, , ,,,,,
,165.82,5560,112.36,61.6,28.5,166.19,0.815,0.820, , ,,,,,
,166.57,5680,113.75,58.2,28.5,166.94,0.820,0.820, , ,,,,,
,167.32,5760,114.93,57.3,29.3,167.69,0.820,0.820, , ,,,,,
,168.07,5840,115.48,54.7,29.3,168.44,0.820,0.820, , ,,,,,
,168.83,5840,49.09,24.3,43.5,169.21,0.850,0.875, , ,,,,,
,169.58,5680,13.61,13.9,37.5,169.96,0.785,0.835, , ,,,,,
,170.35,5560,10.97,11.7,37.5,170.71,0.005,0.820, , ,,,,,
,171.10,5480,10.62,11.3,37.5,171.48,0.000,0.010, , ,,,,,
,171.88,5320,10.48,11.3,37.5,172.27,0.000,0.010, , ,,,,,
,172.65,5240,10.00,10.9,37.5,173.02,0.000,0.010, , ,,,,,
,173.40,5160,9.93,10.9,37.5,173.77,0.000,0.010, , ,,,,,
,174.15,4600,9.37,10.0,37.5,174.55,0.000,0.010, , ,,,,,
,174.92,3560,7.29,7.8,37.5,175.31,0.000,0.010, , ,,,,,
,175.69,3440,6.04,6.5,36.8,176.07,0.000,0.010, , ,,,,,
,176.44,2600,5.07,4.8,30.0,176.84,0.000,0.010, , ,,,,,
,177.21,2600,4.09,3.5,30.0,177.59,0.000,0.010, , ,,,,,
,177.98,2560,3.89,3.5,30.0,178.34,0.000,0.010, , ,,,,,
,178.73,2520,3.68,3.0,30.0,179.10,0.000,0.010, , ,,,,,
,179.48,2480,3.61,3.0,29.3,179.86,0.000,0.010, , ,,,,,
,180.23,2400,3.47,2.6,29.3,180.62,0.000,0.010, , ,,,,,
,181.00,2400,3.54,3.0,29.3,181.38,0.000,0.010, , ,,,,,
,181.75,2360,3.54,3.0,28.5,182.14,0.000,0.010, , ,,,,,
,182.50,2320,3.47,3.0,28.5,182.87,0.000,0.010, , ,,,,,
,183.24,2280,3.47,3.0,28.5,183.62,0.000,0.010, , ,,,,,
,184.01,2240,3.33,2.6,27.8,184.38,0.000,0.000, , ,,,,,
,184.76,2200,3.33,2.6,27.8,185.14,0.000,0.010, , ,,,,,
,185.53,2160,3.12,2.6,27.8,185.90,0.000,0.010, , ,,,,,
,186.28,2120,3.12,2.2,27.0,186.66,0.000,0.010, , ,,,,,
,187.03,2080,3.12,2.2,27.0,187.42,0.000,0.010, , ,,,,,
,187.78,2040,2.98,2.2,27.0,188.17,0.000,0.000, , ,,,,,
,188.53,1960,2.92,2.2,26.3,188.92,0.000,0.000, , ,,,,,
,189.29,1920,2.71,1.7,26.3,189.67,0.000,0.010, , ,,,,,
,190.05,1840,2.71,1.7,25.5,190.42,0.000,0.010, , ,,,,,
,190.81,1760,2.50,1.7,25.5,191.17,0.000,0.000, , ,,,,,
Can someone cipher that???
  #27
Old 02-27-2007, 08:45 PM
alias747's Avatar
bump
boettger1
09-28-2014 11:50 PM
swoyekr
02-07-2008 11:42 AM
AudiOso
06-19-2007 03:23 PM
hurlyblinkboy
04-16-2006 05:20 AM
Quick Reply: Ok time to get to the bottom of this!(Added VAG log)
