Sponsored by:
Sponsored by:
oil sludge
Old 01-22-2008, 11:15 AM
texasboy21's Avatar
Default RE: oil sludge
ORIGINAL: Sherman Banks
You've put 13k on your 1.8 with only 1 oil change??? You should be changing that out within 3k, 5k tops.
No, as i said before this is the second oil change. bought the car, drove 7000 miles, changed the oil, and drove up until now, 13K miles added since i bought it, and changed the oil again....seems to be on par. ill check hte engine for oil, seafoam, and report back.
barrett
Old 01-22-2008, 01:21 PM
cincyTT's Avatar
I'm make believe
sounds like a valve cover gasket if you can smell burning
Old 01-29-2008, 02:57 PM
texasboy21's Avatar
When i changed the oil i did notice some oil outside the engine, but i dont know exactly where so bear with me. there is what appears to be oil on the back, bottomhalf of the engine. while lying under the car with your feet toward the headlights its on the passenger side almost where the engine and transmission meet. Im doing this from memory, but it was further back than the motor mounts, and most of the oil is on something that looks like a george foreman grill cook top. ive never noticed oil pooled under the car tho. anyone know what it is or where the leak could come from??
barrett
Old 01-29-2008, 03:30 PM
Papachristou's Avatar
cam tensioner gasket maybe? they are known to last 40-60k on b6s
Old 01-29-2008, 08:01 PM
auditech79's Avatar
Yeah the cam seal, and valve cover gasket combo. Do both at the same time. The cam seal only costs like $5 at www.ecstuning.com its putting it in that sucks.
pimpinb5a4
04-26-2012 07:40 AM
manse
07-17-2008 11:05 PM
alex05
06-15-2008 06:40 PM
duburban
08-16-2007 07:38 PM
kd
04-26-2007 11:05 AM
Quick Reply: oil sludge
