Oil sludge...
Oil sludge...
Hi there,
the low oil pressure lamp came on last night and this morning I took my car to the dealer and they said its an oil sludge. I've been reading a lot about it and realize its pretty bad but my dealer said that Audi covers this if the car is less than 8 years old and/or has less than 80,000 miles. They said it'll be a couple of days and they will need to order all the parts. My question is, how do they fix the problem? Do they change the engine or rebuild it and if they rebuild it what do they do to the engine? Later on, does it say somewhere (title or carfax) that the engine was rebuilt? Btw, the car is 2003 A4 1.8T 37,5000 miles.
Thanks
Thanks
RE: Oil sludge...
What kinda oil have you been putting in it man... and how often?
And yeah it is a pretty big issue... unsure what the dealers actions are. Just make sure they don't ask you to pay any fees. From how you typed it they seem like a decent dealer (If that even exsist)
Good luck with the issue
RE: Oil sludge...
Well, I bought the car maybe 3 months ago and in this period I changed oil only once. I had Pentosin synthetic oil 5-40 in it. I don't know what the previous owner used and how often they changed the oil. The dealership seems nice abt the issue, they already got a rental car for me while my car is being fixed.
RE: Oil sludge...
just consider it a great thing you caught it when you did! and the dealer is just taking care of it for you
I had a sludge issue in my 2000 1.8T and I got rid of it myself.. long story short they will probably replace the oil pump first and open up the valve cover and clean out any sludge in there ..also when they drop your oil pan they will clean that up too..
thats probably about it
I ran kero and diesel in my engine and performed a auto rx treatment which I am almost thru with
no more oil light for me!
RE: Oil sludge...
I don't have previous owner's records but I think that the car was being leased from the same dealership so they might have access to the maintanance records. Btw, I got the car back today, it took them 2 days to fix everything and the total was around $1,900. If anyone cares, from the receipt i see that they replaced oil filter, changed oil, replaced oil pipe, line, several gaskets, washer, several pipes, valve, hose, gasket set, some clips...and they covered everything like they promised so can't really complain :-)
