Oil sensor
RE: Oil sensor
Either your sensor is bad, you have very low oil, or very low oil pressure.
Check your oil level, if it is OK, then that isn't the problem.
If the light is now off, drive the car gently to a trusted mechanic and have him check the oil pressure. If the oil pressure is well within specs then have the sensor replaced.
If the oil pressure light is on, do not drive the car but have it towed to your mechanic. Low oil pressure and driving don't mix.
jkjersey
B7 Models
06-17-2013 10:31 AM
audiblaze
12-11-2011 03:08 AM
beholder
06-01-2010 09:00 PM
neomaxddr
04-01-2009 04:16 AM
TTsteve
05-07-2006 01:34 AM
