Oil retention valve
RE: Oil retention valve
Cold for a few moments and then once it's hot, after a good hard drive.
I'm thinking retention valve is clogged up and not shutting fully so the pressure is being lost, or the oil pump is packing up, but no pressure light on.
Particularly if the noise occurs only on idle, it sounds like oil starvation of the cam chain adjuster, caused by leaky cam seals (if you are lucky; been there ... done that) or sludge buildup (if you are unlucky). Can you isolate the noise to the back of the cylinder head?
vtraudt
10-01-2019 08:28 PM
stevent3652
12-27-2008 06:59 AM
killerrobotjews
08-26-2006 06:49 PM
