Sponsored by:
Sponsored by:
oil level 1.8t
Old 10-07-2007, 03:45 PM
dmichael's Avatar
Default RE: oil level 1.8t
Yes, I did change the oil filter with a new Mobil 1 high capacity oil filter that is about twice the size of the previous filter. I am using the 5w-30 full synthetic from Mobil 1. I will also order the new dipstick as soon as ECS opens on Monday. If the oil level is still to high, I will try and slowly drain some oil from the drain plug. I hope this is the problem. [:@]
Old 10-07-2007, 03:47 PM
dmichael's Avatar
I also forgot to ask, the picture above I ask “what is this” does any one know if this is a sensor or something like that, it looks to be something of that sort but I cant tell. Or even a placement lock for the dipstick. And again I’m new to the Audi world that’s why im not certainty. I guess I will have to invest in a book.
Old 10-07-2007, 03:48 PM
cincyTT's Avatar
I'm make believe
yeah, to much oil can kill cats and o2's
Old 10-07-2007, 06:36 PM
david9999's Avatar
The snapped off funnel is the problem. Your dipstick is going down an inch too far. Getcoolparts.com or ECS has them for about 6 dollars. The hardest part is getting the broken one off. the easiest way is to use a dremel and a small cut off wheel to cut through the plastic. The new one clips on easily.
Old 10-07-2007, 07:08 PM
Audi_Skydiver's Avatar
ORIGINAL: david9999
Just make sure you don't get any plastic pieces in your oil!
Josh
Vannylasky
07-26-2012 05:56 PM
styxl
01-28-2011 09:21 PM
dmayer75
04-28-2008 09:14 PM
jfa_16
09-19-2006 04:37 AM
audilover04
05-08-2006 07:35 AM
Quick Reply: oil level 1.8t
