oil change help
![Default](https://www.audiforums.com/forum/images/icons/icon1.gif)
The most common problem people have when changing their oil for the first time is locating the oil drain plug.
Once you get your skidplate/flimsy plastic off from under you car, the oil drain will be very close to the front end of the car.
![](http://i5.photobucket.com/albums/y198/ISRSnuff/DSCN0779.jpg)
The bolt with KKB on it is the drain plug. I think it's a 17mm. The part that is disconnected in the pic is the oil return line from the turbo- Don't mess with that unless you are taking your turbo out. I disconnected mine because I was installing a new turbo.
sollyd25
06-27-2008 01:52 AM
