Sponsored by:
Sponsored by:
Oil Change 12Valve
Old 12-20-2005, 09:44 PM
Dj Spiel's Avatar
Default Oil Change 12Valve
Is it ok if I use 10W40 for my Oilchange?
I cannot remember if I used 10W30 or 10W40 last time I know it was castrol.
Old 12-20-2005, 09:45 PM
AudiTech04's Avatar
Default RE: Oil Change 12Valve
Use 5w-40 im pretty sure its the recommended weight
Old 12-20-2005, 09:49 PM
Dj Spiel's Avatar
Really? Isnt it bad to change oil can't u fukk engine. When I spoke to Audi they said 10W30 or 10W 40
Anyone else?
ORIGINAL: AudiTech04
Old 12-20-2005, 09:52 PM
BFlan2001's Avatar
if you're changing the oil you can use a different weight. i believe audi recommends 0w40 for the 12v, but it might be 5w40...i've got high mileage and my car eats up 0w40 like water, so i decided to go with some royal purple 20w50. no more oil consumption problems
Old 12-21-2005, 01:29 AM
Dj Spiel's Avatar
What's diff between 5w & 30W or 40W
Old 12-21-2005, 03:57 AM
flyboy's Avatar
its the weight of the oil and to say it simply the colder the temp outside the light the oil as for yours, check the owners manual, it will have a rundown of the diff weights and temp ranges. get the one that matches the season.
Old 12-21-2005, 11:43 AM
bhj0887's Avatar
I usually go with a 10-30 or 10-40 during the summer.
I'm using 5-40 now and it's about time for another change.
Old 12-21-2005, 10:11 PM
Slowb5's Avatar
mobil 1 fully synthetic 5w-30
Old 12-21-2005, 11:47 PM
John_E's Avatar
It depends on where you live and how cold it gets in the winter.
Most automakers recommend 5W-30 on most of their late model cars, but VW engines tend to require a slightly heavier oil. You cannot go wrong with a 5W-40 or 0W-40, but all of these are synthetic and may be overkill for the SOHC 2.8. (These oils are MANDATORY in the 1.8T sludgemonster, and I use Mobil 1 0W-40 year-round in the Passat 1.8T, with the biggest oil filter I can cram between the adaptor and the left engine mount.)
I live in weather wimp coastal southern California. My 1996 Audi 2.8 occasionally rattles on cold starts with 10W-40 Castrol GTX, but I am currently running a course of Auto-RX, so I cannot prove that a 10W-X is too heavy for winter use. My current thinking is 10W-40 dino in the summer and 5W-30 dino in the winter, on a 6 month or 3k mi = 5k km OCI, for city driving. Alternatively, I could probably double the OCI with an XW-40 synthetic. (The only difference between a 0W-40 and a 5W-40 oil would become apparent in a northern Canada winter cold start.)
Old 12-22-2005, 11:43 AM
hb972.8q's Avatar
in the past i have always used 5w-30 i just changed to 5w-40 both amsoil. the 5w-30 was the xl formaly known as 7500 and the 5w-40 is euro formula.
Quick Reply: Oil Change 12Valve
