OFFICIAL: eBay Short shifter installed!
First off I would like to say I regret putting off installing this.
To install the short shifter I used this AudiWorld writeup.
I followed it basically to a T until 10b. The bolts mentioned were NOT torx but they were 5mm allem bolts.
http://pictureposter.audiworld.com/73397/bolts.jpg
Once I removed those allen bolts and everything else mentioned I took out the asssembly.
Thats where I went a little off from what the directions said. I just took off the small circlip for the push down reverse spring. Then I removed the larger one holding the plastic ball in palce and removed the whole shifter rod and poped the ball out.
http://pictureposter.audiworld.com/73397/3.jpg
Fast forward here... I couldn't for the life of me get the mentioned clips in step 20. I just left those alone and it seems fine for now.
http://pictureposter.audiworld.com/73397/5.jpg
I used the slot with the largest reduction. I used blue lock tite on the bolt holding the fork to the shifter rod.
After that I positioned it in the can and put everything back together. It was a real bitch to pull the housing back up to put in the 4 10mm nuts. Also, the rectangle washer and bolt combo was also a bitch to install. I used a little ducttape to hold the bolt in place with the washer.Once those were in the install was a breeze.
The whole process took 3 hours. I know... I took my time, and it was a learning experience. To be honest, this has been the best $42 I have ever spent on a car. The shifts are FIRM, percise and REALLY SHORT! This also eliminated a little bit of slop in the stock shifter.
If you're thinking about buying one stop and just get it already!
96, 98, a4, audi, b6, ebay, focus, guide, insta, install, installation, installing, instructions, shifter, short
