OEM Turbo Question?
RE: OEM Turbo Question?
yeah thats pretty bad when the shaft breaks. Im surprised the motor wasnt hurt at all. Did the compression test pull straight across the board, no cylinders were considerably lower? I guess thats a good way to buy one, then you know your starting off perfect. As long as it doesnt have sludge build up.
Im going to have to check out the G-popshop
ORIGINAL: eurwaudi1.8
Oh its blown bigtime the shaft broke due to a feed line blockage. I went to the guys house to check the car out befor i bought it he had already removed the turbo. There were no pieces missing from the turbo veins but I did a compression check just to be safe and all 4 were good so i bought the car.
I just checked them out. Pretty decent pricing. a K04 for around 600 is a pretty good deal. I wish I could just make my K03 a K04, lol.
ORIGINAL: akielb
G-pop also sells rebuilt turbo's - so your not puting on a turbo from 98 with a ton of miles on it.
I just checked out that site too, actually you can make your ko3 into a ko4 for $100 i think. Go back on the site and check it out. Its under turbo upgrades. I might actually consider buying a rebuilt ko3 and upgrading it to a ko4 thaks alot akielb
I just bought a 1998 A4 1.8 quatro. The turbo is blown got a good deal on the car otherwise mint pearl white/black leather.
#19
ORIGINAL: akielb
they can do that - the change will cost you $425 with $25 S/H to change your stock K03 into a K04 spec turbo
#20
That would fall under a good deal
Yeah I know the difference isn't that much between using your old turbo or rebuilt one from them. Its up to you - allows you to put he $125 somewhere else
About the car - has the timing belt been done? if you don't know or if you don't have a receipt saying when it was done, I would suggest doing it just to be safe. I can't wait till my turbo goes - see thats what i love about these cars - no matter what goes wrong you can always turn lemons into lemonade Good luck
