Sponsored by:
Sponsored by:
o2 sensors
Old 03-14-2005, 07:40 PM
Nasty's Avatar
Default o2 sensors
could bad o2 sensors lead to turbo failure? and could they also trigger the check engine light? because mine came on the other day -although the manuel says its "check emmissions." i kinda wanted to wait on it because i need my car for daily driving this week but im gonna be outta town for the weekend so i thought that would be a good time to get it fixed...is there any real danger in waiting? The light came on last friday and i would bring it in this friday. And could this light also have to do with why im getting terrible gas milage, about 11-12 MPG?
im thinking it could be..correct me if i'm wrong
-Bad 02 sensors
-Fuel injectors
This what the light looks like, i know its the check engine light but the manuel says its check emmisions and if its blinking then there could be cataltic coverter damage...mine is not
[IMG]local://upfiles/5074/B4D42D7ED82B4B59928234FD648F88A1.jpg[/IMG]
Old 03-14-2005, 08:10 PM
CRAZYHAWK's Avatar
Default RE: o2 sensors
Get the error codes.
Old 03-16-2005, 03:22 PM
Nasty's Avatar
P1136 Fuel Air Metering
im takin it to the shop today
Old 03-16-2005, 05:03 PM
brrman's Avatar
wild guess... MAF
Old 03-16-2005, 07:08 PM
Nasty's Avatar
yeah thats what i was thinking too, but then i brought it in and they said it was a vacum hose and they would fix it for about $100 and see if that fixed the problem, they said its prob the same reason that im getting about 11-12 MPG in gas
should be getting it fixed tomarrow, ill let ya know how it turns out
Old 03-16-2005, 07:37 PM
brrman's Avatar
$100 to fix a vacuum hose!????
Get them to show you which hose it is and then go change it yourself.
Old 03-17-2005, 09:34 PM
Nasty's Avatar
yeah, thats what i should have done...it was $20 in parts and $100 in labor, it was there for like 1.5 hours and they charged me $45 just to get the error codes (which i allready had, and tell me what i needed to buy). But they fixed my vacume line and said that when they had it hooked up the a machine that the Air mass meter was fluxuating a little, they said that might have been due to the leak and it might reset itself but they wern't sure.....
sure hope i dont have to get that AMF replaced, they said that if i did it would be about 300-500 for the parts, and god knows what for the labor.
But the check engine light is off.
And it seems to be idleing a little rough in nuetral for some reason
Old 03-18-2005, 02:40 AM
brrman's Avatar
You can get an MAF for anywhere between $50 and $250 at ECStuning.com - depending on your engine code.
Old 03-18-2005, 02:23 PM
smythe's Avatar
I got a MAF for less that $100 from the dealer after a shop had quoted me $350, Id look around its not hard to install your self.
As far as the shop you are using, I would bring it to a place that sepcialized in audi/VW's if "the MAF might reset itself they weren't sure" all the readyness codes can be reset by someone who knows even a little about the car.
Old 03-25-2005, 05:26 PM
Nasty's Avatar
ORIGINAL: smythe
well the shop that i did take it to does specialize in audi's...but they have been know to be very pricey, somthing i experenced when getting my hose fixed... but if i did need the MAF replaced then would it be okay to take it to any other shop, or should i find another one that specilizes with audi's/VW?
Quick Reply: o2 sensors
