o2 Sensor problem
o2 Sensor problem
im getting this code 16514 P0130 O2 Sensor Circuit - Malfunction (Bank 1 Sensor 1) A
so i changed the sensor yesturday cleared the code drove for 30 minutes light stayed off. parked for 20 minutes and when i got 1500 feet the llight came back on
so what should i check now? i want to get this figured out without going to the dealer....
the car is a 2002 1.8tq A4
RE: o2 Sensor problem
the light came back but did you get it scanned again? it could be a code for B1S2 this time because the 2 sensors work together and there is a range where everything is right. the new sensor could mess with things a little bit but it should correct itself. car should run fine too.
