Noise @ Front Right
Noise @ Front Right
I was just driving through town and noticed a grinding noise coming from my front right end. The noise made me think it was some sort of plastic grinding on the wheel but i didn't see anything. I had my computer in the car so i thought i'd just stop and ask! At this point i'm thinking it must be the bearing. What should I look at and what should I look for?!
RE: Noise @ Front Right
Grinding? The wheel bearing or brakes are the only things that could make a grinding noise.
A wheel bearing kinda sounds like your tire is made of concrete.
A brake grind will generally go away when you depress the brake.
Other than that you could have a tire howl.
My wheel smelled like brakes and the grinding stopped when i hit the brakes. What would make a wheel want to lock up like that? Car is at the shop, what do you think they will tell me?
nitrogen
07-03-2009 12:10 AM
