No radio stations
No radio stations
i had an alpine 9807headunit installed in my 2001 a4 for some reason i cannot here any radio stations they come in really static, i thought maybe the guy forgot to connect the antenna wire checked that it was fine i checked almost everything i even put the stock radio in to see if he messed up the antenna or amps anything and it worked fine maybe someone has a suggestion what to check maybe he didnt give power to a certain wire anything i dont know please help its been driving me nuts i appreciate all the answer i can get thank you
RE: No radio stations
Hey Sicilianaudi.
I have the same problem with my 2000 A4 radio stock from the dealership, so please if u got ur problem resolve can u send some info on how to fix mine please. Cause Im at the point where I listen to is mostly CD cause of the static I get from my radio. U mentioned that u did a few things before posting on the audiforums like antenna wire check & put the stock radio out. How did u do all that, where the booster are located & antenna also cause the things with me I don't known where in the car to start. So please if u got ur problem resolve some info on how to fix mine. Thanks
do you have the fancy prancy power antenna adapter thingy? Some wierd thing needs to be bought... it's like a long aluminum cylinder, about 9mm in diamter, and maybe 100mm long?
Course, I have that thing, and still my radio sucks. (I have an alpine CDA-7998)
same thing happened to me when i put my clarion vrx935vd in, only get one station i dont hate, cd's ever since. when i asked the guy who installed it he said its probably because our cars use that attenna that is built into the windshield
My sony gets great reception actually too good of reception. I installed the power antenna adapter from crutchfield. The piece cost like 12 bucks, now I have satelite radio and never listen to normal radio ever. Or I plug in my ipod so I never carry cd's either.
ok i went to this guy by my house who is benn doin radios for like 30 years as soon as i told him my problem and what i thought it was he goes no its the booster the stock radios come with them inside or somthing like that so he had the adpter it was 20 bucks and that was the problem all it does is go in between the antenna wire to the radio i was like you have to be kidding me but yea that was the prblem, it looks exactly like what headshok2002 said so guys if u ever install a H/U make sure u get this thing if u need it cause i went to hell and back trying to figure this out so thanks guys for your help
