No power in the rain!!!
I have a 2001 A4 1.9 TDI. In the rain or after the car wash there is no power and will often die in first gear. When you gte going after you change gear, it audi will lose power for 2-4 seconds before kicking in. This will continue until dry and it's very sluggish.
Any help please!!
Any help please!!
RE: No power in the rain!!!
yeah sounds like you are getting water into your intake. just be sure all of your connections are tight. The MAF is located at after the air box it is the only sensor on/in the intake tube. You can not miss it when you look for it.
ORIGINAL: sdboarder84
IF you drain the oil and its milky, then you have been sucking in water and need to change it a couple times to get it all out. But i have seen people that have had the ecu's get wet with rain/washes, that could also be something to consider.
