no power on accel
Old 06-30-2007 | 12:15 AM
gekabech's Avatar
Default no power on accel
ijust bought my first audi today "2002A4 1.8T 78k miles" I can't hear the turbo? and when i first take off the car won't get out of
its own way. Is the boost supposed to be noticable on this model?
Any help or advise would be great.
Thanks.
Old 06-30-2007 | 12:26 AM
a4 1.8t's Avatar
Default RE: no power on accel
get used to it.. haha. try turning ur ac on then starting out.. the turbo is really small and you cant really hear it unless your in a tunnel listening for it or get a cone filter intake. get a reflash its worth the money, about $500
Old 06-30-2007 | 12:53 AM
gekabech's Avatar
will the reflash help with the lag? And could it be a DV problem?
Old 06-30-2007 | 01:02 AM
Belligerenceâ„¢'s Avatar
you shouldn't ever notice any lag in a stock A4 1.8T. the turbo is tiny, meaning it spools almost instantly. our engines develop their peak torque at a very low RPM, around 2000 or a little less even.
is your check engine light on?
Old 06-30-2007 | 01:13 AM
gekabech's Avatar
No cel, andthere is a definite delay in getting power to the ground
Old 06-30-2007 | 01:14 AM
gekabech's Avatar
I wonder if the turbo even works.
Old 06-30-2007 | 01:21 AM
a4 1.8t's Avatar
you probably have a boost leak. possible the dv......
im not sure on this but, your wastegate could be stuck and your not boosting at all?
Old 06-30-2007 | 02:49 AM
gekabech's Avatar
I just went for a drive with the windows down and sounds it makes are a lot more hissing than whining, so
a boost leak might be the culprit.
Old 06-30-2007 | 03:24 AM
a4 1.8t's Avatar
most likely is. get a boost gauge, imo every car should have them stock, best way to tell if you have a major leak which it sounds like you do. if you do get one you should be spiking around 9 psi and the vacuum should be aroudn 22hg
Old 06-30-2007 | 03:30 AM
gekabech's Avatar
I'll try that tomorrow, thanks for all the help.
ledzepp2994
01-30-2009 02:24 PM
brodieone
12-06-2007 12:23 PM
tarz4play
09-14-2006 10:00 AM
Cheese Eater
08-24-2006 07:12 AM
s4_revolution
03-14-2006 07:57 PM
