no ko4 install?
RE: no ko4 install?
just take out the k03 and put in the k04, only diff between the 2 is inducer blade design... you need to pull your lock carrier, and you will need either a deep offset 17mm wrench or a 3/8 drive universal joint to get all the bolts off the exhaust manifold to the turbo. use lots of penetrating oil.
RE: no ko4 install?
i have to replace the wastegate on my k03, if you would like i can take pics of the process of getting to the turbo and getting it off/getting around it... not a big deal, just lemme know before i do the wastegate.
RE: no ko4 install?
are u sure u checked audiworld? :-\ http://www.audiworld.com/tech/eng.html go down a bit its called K04 Turbo Upgrade ic ant link you to the exact page since it does not let me.
