newbie question...
newbie question...
i am curious... as i read through some of these threadsi see people saying i have a fault code, or somthing of that nature... im wondering if the car itself gives a code on the screen in the car or if these codes are what people get when they use their vag com??
RE: newbie question...
Anytime your car has a check engine light (and sometimes when it doesn't) and there is something wrong with it there is a code that can be read. You can take it to an autozone or schucks or wherever and they can tell you what that code is (its a number) and that corresponds to a certain problem.
Example, I am new to audi's as well but on older Honda's the ECU would actually blink a certain number of times and that was the code. It is a bit more complicated than that now but same thing overall.
vagcom is a program for your laptop. you hook your laptop up to the car via a cable from ross-tech, or the ebay one that's much cheaper but can't log data. you can still check and clear codes tho. you can download the program from the ross-tech website
ORIGINAL: A4speed
easiest thing to do is use autozones code reader and they let you use it for free.
