New Tires
New Tires
I was told that because my two front tires are worn, that i need to change all four tires. the person said that it has something to do with the quattro and that it says in the manual to change all four tires. is this true or is he just trying to get me to buy two more tires?
RE: New Tires
No it's true. If you don't have tread that is within a certain range of each other it will cause all your tires to wear fast and it might mess up the quattro since it will be turning at different speeds (the wheels).
Someone correct me if I am wrong but I have heard this many times before.
RE: New Tires
$525 shipped for the wheels and tires - info: https://www.audiforums.com/m_648498/tm.htm
RE: New Tires
Its always recommend to replace all four at the same time. But if you just need two put the new ones on the front, for obvious reasons. I work at sears auto, if a car has awd/4wd we can't sell just two tires. So yes he was trying to get you to buy two more tires but its really the right thing to do on these cars.
Oh btw read this https://www.audiforums.com/m_474623/tm.htm
Sounds like you got alignment issues.
ORIGINAL: kolan67
damn my tread is so messed up.... my right side wheels are brand new... and my driver side wheels are almost slicks
bigatstyle
11-09-2012 08:29 AM
pindonesia
11-16-2005 11:43 PM
jmerrell
08-25-2005 04:01 AM
miamitrails
08-17-2005 03:08 PM
