New owner -- cranking issue?
Hello,
I am not quite sure if there is a thread like this already, but I haven't been able to find one.
I own a 2003 A4 1.8T and it seems like every so often, when I start the engine, I have to crank for 4-5 seconds before the engine turns over whereas normally, it takes about 1-2 seconds. This seems to happen whenever the engine is warm (i.e., shutting off the engine for < 1 hour). When I start it up in the morning, it usually turns over just fine. I wanted to know if anybody else had this problem before and if so, how they fixed it?
Thanks.
Thanks.
RE: New owner -- cranking issue?
i have an 03 with a 1.8T in it and on average my drives are over an hour long and when I shut off, i let it run for about 2 min, then when i get back in to start up, it helps to turn the key to on for about 30 seconds and then crank it over.
i ahd the same problems, like it just seems like it takes too long to finally engage but try this and it might help a little, it does in mine.
I wonder if I should take it in to the dealer to have it looked at. As of now, it doesn't seem like it's that big an issue. Or should I just wait until the major tune-up before 50K miles to have them handle it then?
