New headlights.....one problem????
Hey i just purchased some new angel eye headlights for my 99 A4 1.8t. Well the housing fits in fine my problem is my stock turn signal bulb(not the acutal bulb...but what the bulb is currently sitting in) will not fit into these aftermarket lights hole? anyone else had this happen. is there an adapter or somthingi can buy that will enable them to fit ?
thnx
thnx
RE: New headlights.....one problem????
well there are two bulbs tht came with my head lights but the turn signal bulb did not that is why i am using it off my stock headlights. but for some reason what ever the thing is called tht the turn signal bulb sits in the pattern does not quite match these angel eye ones?
are you saying i should not even use the two bulbs they gave me that came with the headlights?
I agree with rcons. I installed some smoked e-codes and had the same problem.
I used the stock bulbs and sockets and it worked well. It didn't fit perfectly, so be careful when you thread it, not to fully thread it in.
this happened to me. the nubs on stock socket doesnt match up with holes to let it in.
try this pop one of the nubs in while holding socket at an angle. turn a little till the next nub is ligned up then use a little force to pop it in there. then turn a little till you get the third one in there. just mess with it/use a little force.
watch out! i have these crappy ebay lights (upgrading to ecodes asap) the plastic that covers the turn signal will melt and make your bulbs burn out eventually. they also let moisture in. If you are keeping them take it apart remove the plastic thing over the turn signal. and seal the housing with silicone. otherwise they will look like mine and you will have melted plastic and moisture build up.
I wish i had never gotten them and just bought ecodes right off the bat. but i needed a temp solution until i got money.
btw: good luck getting the angel eyes to work!
