New Audi Owner, Problems. Help!
So I recently (two weeks ago) purchased a 2002 A4 1.8t 56,000 miles. After 6 days CEL light came on (P0411 seconday air incorrect flow)...I'm sure this will co$t me.Now wheneverI back outfrom reverse and begin to turn the wheel i fill a click/grind in the gas pedal. It only does this after making a tight turn from park either drive or reverse (no other times)and I can feel it distinctly in the pedal. Any thoughts for the newbie?
Thanks!
Thanks!
RE: New Audi Owner, Problems. Help!
P0411 is the secondary air injection system possible leak in the pipes the other is the C/V joints and only happens on tight turning ( take it back to whom you bought it and ask them to repair the C/V joints ( especially if it was from a garage ) and they should sort the air injection problem out as well
