neuspeed rear sways
Old 12-04-2005 | 05:24 PM
ExpLlclT's Avatar
Default neuspeed rear sways
nuespeed rear sways im looking into
330$ neuspeed.com/achtuning.com 25mm
273$ greedspeed.com 19mm
250$ modacar.com 22mm
which size should i get ?
i took a ride in a 1.8Q advant and it had a 19mm with kw 2 coils was great want to have no body roll but i don't want to feel huge shocks is the 19mm perfect ?
(i have a 2.8Q)
Old 12-04-2005 | 05:39 PM
BFlan2001's Avatar
Default RE: neuspeed rear sways
go with the 19mm. 22mm would be too stiff imo and it might also crack your subframe.
Old 12-04-2005 | 05:41 PM
bhj0887's Avatar
I'd go with the 19mm.
22mm will probably give you more oversteer then you want.
If that's really a 25mm rear bar, stay away. That will most defenitly crack the subframe without some well designed supports.
Old 12-04-2005 | 06:20 PM
juju4uofa's Avatar
Let us know what you get and how well it works with the factory sport suspension. Doesn't neuspeed or someone make an adjustable rear sway?
Old 12-04-2005 | 09:04 PM
ExpLlclT's Avatar
thx guys but ^^ im planning on doing coilovers with the sway Koni/STaSIS street versions i will let you no but the car i rode in was excelent no body roll
Old 12-04-2005 | 09:42 PM
headshok2002's Avatar
Damnit I want a rear swaybar... maybe even a front... front's dont increase stiffness (percentage wise) as much as the rears do... so if you do front and rear, you'll still have more oversteer than before... but it'd have to be crazy! But yeah... definately want to get at least a rear! 19mm will be what I go for.
On a side note, can you not get subframe connectors or anything for our cars, to allow for a 22mm bar without any danger?
Old 12-04-2005 | 10:33 PM
BFlan2001's Avatar
i bought my neuspeed bar used and it came with a couple of heavy duty subframe brackets that would make it much more secure, but even with those i don't think i'd risk a cracked subframe for a 22mm...especially because i already have PLENTY of oversteer with my 19mm
Old 12-04-2005 | 11:10 PM
I guess what I meant, was that if I were to do both front and rear, I'd likely go 22mm.
superdooperme
06-05-2009 04:47 AM
TheLastNexus
05-28-2008 07:24 AM
just_D
08-17-2007 11:21 AM
adriancdn
04-26-2007 05:00 PM
A3guy
03-06-2007 04:07 AM
Quick Reply: neuspeed rear sways
