need some audio help
RE: need some audio help
it does have the LPF. any idea how to get that signal. I'm afraid of going in there and splicing and stuff then finding out I totally messed up. I guess I would be doing post amp?
ORIGINAL: smokeU
After the female rca's are spliced in you plug in the male rca's and run them to the trunk or wherever your amp is, make sure to run the rca's on the passenger side to avoid interference with all the electrical stuff on the drivers side part of the firewall area.
got it, that makes perfect sense! thanks a lot man. so its pre-amp tap? now I just have to search to figure out how to get the headunit out. haha! fun stuff!
signal problem solved thanks onepoint8tee. now who makes the best wiring kits? I know they are pretty pricey but quality wiring is a must. also if anyone has directions or a link for getting the headunit out I would appreciate it. I know it involves a couple butter knives if you dont have keys. lol.
ok so got the headunit out. now my problem is that the amp wont power on. I have the remote wire to the 75x under the kick panel and the amp powers on for 3-5 seconds then the little light just goes out.
I have done this with signal connected and without. is the amp bad or do I just need to find a new ground or what? i have it grounded to one of the metal clips on the floor of the trunk. under the carpet i have the ground screwed in between the metal clip and the trunk floor.
I have power because if I wiggle the ground it kind of sparks a little. please help! I'm about to just bring it somewhere and have them do it but I would feel a lot better if I could accomplish this. thanks.
