Sponsored by:
Sponsored by:
Need to replace turbo
Old 02-01-2006, 07:16 PM
dafrazi's Avatar
Default RE: Need to replace turbo
If you're gonna do the timing belt, do it at the same time as the turbo. Taking everything apart for the timing belt leaves a lot more room to work with the turbo which makes the turbo install easier. But, if you have problems afterward it will be harder to determine what did it...the turbo install or the timing belt install.
Old 02-01-2006, 08:07 PM
onepoint8tee's Avatar
Not trying to jack the thread, but, will a k04 work with the giac software for my k03?
Old 02-01-2006, 08:17 PM
Yuikio's Avatar
^Yep.
Old 02-01-2006, 08:18 PM
ORIGINAL: Yuikio
^Yep.
So if i get a k04, there is no need for another giac flash correct??? Just want to be sure.. Sorry for the newbishness.
Old 02-01-2006, 09:28 PM
audiboy1618's Avatar
Nope, it will run fine. Just wont have near the potential ko4 software will. But it will fill ALOT stronger then the ko3. Prolly a solid 220+ hp.
Old 02-01-2006, 09:32 PM
gregp1962's Avatar
I'm right i n the middle of doing it myself too. Definatly a DIY job
kemso109
10-19-2015 06:45 PM
jaymac
08-29-2008 01:26 PM
delwyn
12-12-2007 04:31 AM
kemso109
10-19-2006 11:53 PM
aziatic
09-05-2006 04:03 AM
Quick Reply: Need to replace turbo
