Need Help...A4 making a wierd noise...
Old 12-17-2006 | 07:32 PM
renoaudi's Avatar
Default Need Help...A4 making a wierd noise...
Have an '03 A4 quattro3.0L w/ tiptronic. There's a noise coming form the engine compartment when the the engine revs down. The noise sounds like a jet engine and happens between about 2000 rpms and idle. It is noticable after the vehicle idles for about 3 to 5 minutes. Thoughts
Thanks for any help!!!!
Old 12-19-2006 | 02:43 AM
dankhound's Avatar
Default RE: Need Help...A4 making a wierd noise...
First thing that comes to mind is the secondary air pump but the timing is off. Also check your electric fans. Maybe one of them is coming on.
Old 12-19-2006 | 07:53 PM
AteUrV8's Avatar
is it like a whistle/whine??? and it sounds like a jet, lol.... does it start whinding down if you let off the gas at 5k RPM's in second gear?? I think i might have the same noise and its either a pulley or a belt or something like that.
fltt
01-08-2011 01:11 AM
qunair
10-01-2010 11:12 AM
2000_2.7t
09-08-2008 04:08 PM
memzback
01-23-2007 02:03 AM
Skeedumbeat
04-29-2006 02:39 AM
