need expert advice -what can this be?
#21
RE: need expert advice -what can this be?
Yes, it did.
The noise was coming from the broken tensioner.
I replaced all the above mentioned parts, and it is back on the road running normally again.
#23
Yeah, I thought about that. I think I did PM you when it first started running bad, to see if you wanted to stop by with the VAG com.
Anyway, we definitely need to hook up sometime.
I did meet Arif one day, he was pretty cool. I'd like to go to one of the drag strips sometime and check that out.
The timing belt change went well. I learned quite a bit about lining up everything, as it seemed the belt may have jumped a tooth or two.
I stopped driving it as soon as I was having the problems, so I think that saved me from valve damage.
Anyway, She's back to rippin it now. Everything is running smoothly, no problems I can find.
#25
Yeah, it was chipped when I bought it.
Here's the list:
Authority chips 1bar
koni coilovers
Some brand of aftermarket cross-drilled rotors
Aftermarket 17's
Looks like a forge dv, but didn't have any writing on it anywhere I could see, its a larger, black metal DV.
Borla exhaust
LLtek grill
custom lower grills
momo shifter
I bought it in November last year. All the mods were done already, and very nicely.
I love the car, it is set up very nicely. It handles and Brakes friggin awesome, and has decent power.
Although now that I have ridden in Arif's car, I dream of a 2871 practically nightly!!!!!
I have done tie rod ends, alignment, ignition module, fog light grills, and now timing belt. Hopefully BT some day!
Here's the list:
koni coilovers
Aftermarket 17's
Borla exhaust
LLtek grill
custom lower grills
momo shifter
