my oil temp gauge doesn't seem to do much... help
01-18T my oil temp gauge doesn't seem to move much.... what is normal opperating temp? what kinds of readings are you guys getting? because mine never goes above about 160... and it starts at 150.............
RE: my oil temp gauge doesn't seem to do much... help
around 175 when it's cold out average about 200 deg, never above 225 (for sure)... on my 1998 1.8tqm...
sensor? guage?...ionno...gl!
yea mine doesn't move very much too, actually i was about to ask the same question. it was once above 200 for a while then i figured out that there is a problem with my oil level and i had to add 1.5 qt oil, from that point it never risedabove 160-170 range. so i thought that might be a good indication of watching your oil level. but i really don't know why it doesn't rise more or why the hell that indicator starts from 150... anyone has an idea?
When youre driving in 10-20 degree temps, its not going to move up much anytime soon. In these temps I have to be driving for 20 mins or more before it reaches 160-170. Summertime is usually about 225.
but it dosnt give you a true reading?? same as a coolant warning ( light ) it also dosnt give any data because its not a gauge,
dont confuse warning lights with actual data ( digital or gauges ) a light is a light its either on or off
ORIGINAL: avant80@2.6
