Sponsored by:
Sponsored by:
My daughters A4 just went to crap! Help!
Old 11-21-2006, 04:48 PM
onepoint8tee's Avatar
Default RE: My daughters A4 just went to crap! Help!
ORIGINAL: Lazer Viking
ORIGINAL: smokeU
the glowing red is normal.
when the hell is glowing red normal...he wasnt driving the car that hard
Its always normal. You dont have to be driving it hard. Check under your hood at night after you drive. But if its an excessive glow, i agree it could be a clogged cat. There will always be codes present if you have a CEL.
Old 11-21-2006, 05:04 PM
Amze's Avatar
Mine glows so much that it gives my car a red neon effect, whats your take on that?! haha
Old 11-21-2006, 05:24 PM
GTOrleans's Avatar
ORIGINAL: smokeU
ill have to agree with Lazer, i doubt she was trying to simulate race conditions at the track.
Old 11-21-2006, 05:30 PM
ORIGINAL: GTOrleans
ORIGINAL: smokeU
You dont need to be racing for the wastegate/exhaust mani. to glow. Have you ever looked under your hood at night after even a modest drive? A forced induction engine produces extrememly hot temps at the wastegate/turbo/cat even if its running stock boost levels- less than 10lbs of boost. Boost/compressed air=HOT... EVEN if you arent pushing 15+psi and going for the best 1/4 mile time.
Old 11-21-2006, 06:30 PM
MadMaxGT's Avatar
Nothing new to report other than I also believe that it could be the cat converter. Yes the car is an automatic and it starts fine, the idle isn't really rough, but no punch to it! It will accelerate slowly, the tranny shifts, but sputtering all the while. I contacted a shop in Woodbridge, VA named "Executive foriegn car service" mechanic "Charlie" seemed nice to talk to and knowledgable. Anyone know much about this shop? I don't mind taking it in, but I will be pissed if this is something minor! Thanks. Max!
Old 11-21-2006, 07:36 PM
BaconBait's Avatar
Take it to Autozone. They do free scans. Post the results here and we may be able to help locate the problem more accurately.
Old 11-21-2006, 08:24 PM
Lazer Viking's Avatar
"onepoint8tee: Its always normal. You dont have to be driving it hard. Check under your hood at night after you drive. But if its an excessive glow, i agree it could be a clogged cat. There will always be codes present if you have a CEL. "
cant... theres a heat shield wrapped around mine =)
  #18
Old 11-21-2006, 08:36 PM
There is not a heat shield wrapped around the exhuast manifold and there is not a heat shield wrapped around your wastegate. If there is, then thats just fucked up!
  #19
Old 11-22-2006, 02:19 AM
tank8970's Avatar
if it goes just accelerates like **** like stuttering couldnt it be one of the coil packs like its running on 3 cylinders
  #20
Old 11-22-2006, 03:38 AM
Amze's Avatar
ORIGINAL: tank8970
Good Sentence.[:'(]
Quick Reply: My daughters A4 just went to crap! Help!
