Sponsored by:
Sponsored by:
my cel loves me
Old 08-28-2006, 06:55 PM
audi_pa's Avatar
Default my cel loves me
So every 10-50 miles i will get a cel. [:@] comes on just cruising. and it all started after i replaced my maf. Do to the car not performing as well. i also replaced my ects and cleaned my its. i put a test pipe in last weekend but have driven with it for 200 miles no problem. and i did the nonfouler mod. any ideas? which o2 sensor is this? is it the one in the back? should i just replace both? the car has 58k on it; engine+turbo replaced at 44k. think the 02 sensor would **** the bed that quickly after putting a tp in?
16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
P0140 - 35-10 - - - Intermittent
17522 - Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High
P1114 - 35-10 - - - Intermittent
Readiness: 0000 1001
00787 - Temperature Sensor in Fresh Air intake duct (G89)
30-10 - Open or Short to Plus - Intermittent
Old 08-28-2006, 07:29 PM
dafrazi's Avatar
Default RE: my cel loves me
That's the rear O2 sensor.
Old 08-29-2006, 12:00 AM
audi_pa's Avatar
are you sure other posts have said it was the precat sensor. need alittle help before i go buy a 130 part want to make sure it is the right one.
Old 08-29-2006, 12:59 AM
audi_pa's Avatar
[sm=feedback.gif]
Old 08-29-2006, 01:41 AM
forcefedaudi's Avatar
I would make sure the o2 sensors arent loose before you go changing them i had a similar problem where there was no code for a while turned out that they where just loose.
Old 08-29-2006, 01:42 AM
audi_pa's Avatar
cool
Old 08-29-2006, 01:45 AM
audi_pa's Avatar
thanks forcefedaudi any help is good help, thanks for the reply, i appreciate it. i will double check that [sm=goodidea.gif]
Old 08-29-2006, 10:05 AM
dafrazi's Avatar
B1 S1 is front sensor.
B1 S2 is rear sensor.
Old 08-29-2006, 02:45 PM
InsaneHatter's Avatar
POST CAT 02 sensor on the fritz.. REAR 02.. POST CAT.. clarification enough..
also your Fresh Air sensor is messed.. the one under the pollen filter..
Old 08-29-2006, 03:38 PM
audi_pa's Avatar
you guys are awesome thanks
Quick Reply: my cel loves me
