My brand new car scared me
Hey Guys,
I have a 2007 Audi A4 with 1500 miles which I chipped with APR at around 600. The other day I was driving up the freeway and I brought the car up to 100mph then all of a sudden I felt complete power loss. The car wouldn't go above 100 and it felt like I was running NA.I was scared shitless. I backed off the gas and exited the freeway. For the next several miles I took it easy but when I hit 2500rpms I didn't feel the turbo kick in like I normally do. A few minutes later I decided to pull over and hold in the cruise control button to change it back to the stock setting. I've never done this before and quite frankly I have no idea what mode it is in right now. You are supposed to look for the blinks according to the manual but it just ends up confusing me. A few times my car wouldn't even start when changing maps even though I let it sit for 10 seconds before starting it again.
So anyway it doesn't feel like it used to but it's better than it was during that scary experience. I don't know what to do. I mean I have taken the car up to 120mph in the past without any issues.The car is brand new and I don't want to bring it to the dealer as I'm pretty worried about them finding out about the chip. Yeah... the dealer can't find out about it by hooking up to the ODB-II port but they can hold in the set button on the cruise control stalk to see if the check engine light blinks abnormally.
Based on what I've read I've heard stories of blown turbos, bad dv, and bad fuel pumps. What do you think?
RE: My brand new car scared me
Sounds like limp mode to me, i dont know about not being able to start it up or the issues you have now. Id be talking to APR before the dealer about it though. I doubt your turbo is blown or anything major. Get your ecu scanned for fault codes. If there are any, write them down, have them cleared (post here to let us know what they are if any)and see what happens.
hmmm, i dont know much about brand new chipped 2.0T's but my advice would be to return your car to stock form and then take it to the dealer and let them fix whatever happened under warrenty....
What is limp mode?
Will the ECU have any fault codes if no lights were ever displayed?
The start-up issue isn't an issue anymore. It just happened a few times after I was trying to switch between stock and chipped mode. I think it's because the map wasn't fully uploaded or something.
ORIGINAL: guru_ck
What is limp mode?
What is limp mode?
A lot of times, if you just recently got chipped, it takes a while for the ecu to adapt to the new settings. When people get multiple programs (stock, chip, race, valet) they switch back and forth so much the ecu doesnt get a chance to fully adapt. Even with just one program it can take a few weeks for the ecu to adapt. A lot of times youll go into limp mode and get some crazy fault codes along with it until the ecu fully adapts. That was the case for me and is with many others, and thats why you should get the codes cleared and see if they come back. If they come back there may be a real problem. Its possible there is a fault code stored that is keeping you in limp mode, until its cleared.
ORIGINAL: guru_ck
Thanks for the help. I'll go to the zone tomorrow and get it checked out.
So I went to AutoZone tonight and they had the ODB-II reader in stock. I just had to put a refundable deposit down. It was so easy to use, this thing had like 4 buttons... read, erase, up and down. So I hooked it up and it didn't pull any codes so I guess I am in the clear. Thanks everyone for your insight, I have peace of mind now. My car is running fine and I brought it up to 120 tonight for a second without any hesitation from the engine. So I guess it was just a one time deal. Thanks again.
-Chris
-Chris
