mounting my amp
mounting my amp
I have a sub box for my 2 12" subs. I am not sure where to mount my amp. Would mounting the amp right to the top of the top cause any of the following: rattling, damage to the amp, a flaw in the box from a tiny tap in screw? I thought about mounting it vertically to the back of the back seat..but i think right on top of the box would work well...as long as it does not hurt the amp at all or rattle causing unwanted noise.
RE: mounting my amp
my amp is a mono amp, i witnessed an install of 2 subs to one mono amp....that is possible/ok, correct? I can run 2 subs off of a mono amp.
Also, when sites say that different power is put out at different ohms, how do you set which ohms for the subs to run at?
