more questions!!!
more questions!!!
i searched so chillout haha so i was wondering a few things
1 are those european front license plates legal in nj?
2 is diy clear corners worth it?
3 when hitting the gas sounds like a flapping sound, maybe i need a new air filter?
4 and when im at like 5k rpms in second floring it it feels like a fuel cut and then kicks back up again
i have a stock 96 2.8
thanks sorry for the noobitity
RE: more questions!!!
1 - Do you require a front plate in NJ? If not then its fine. They are novelty, nothing else.
2 - Its up to you.
3 - flapping sound? You will have to do better than that. When you punch the gas - WOT? Could be something loose such as the belly pan under the car.
4 - You won't get any power past 5K rpm. Actually, don't quote me on that. I am not sure with the V6 as the powerband is different from the 1.8t.
2 - Its up to you.
1 yeah its the law to have one i was wondering if you could use the euro one as a reploacement,
2 would the diy clear corners look good?
3 the flapping sounds sounds like the air filter is clogged i think ill buy a k nd n
4 and our redline is 6200 we should make power after 5 k right?
and do the newer audis {99,01, etc] come with clear corners and lower foglights and 1.8t tailights?
i saw do one piece conversions for your headlights it will be much better, and as far as the other things go the 2.8 has little power period so im not suprised that it doesnt have power over 5000
Yeah and i dunno if you will get any leniency if you have a europlate with your real license # on it. Do the one piece clear corners, e-codes. SO worth it. Look at aRIf's car before and after his one pieces...such a big improvement.
