Mileage went down again, vag logs HELP PLEASE!
So I filled up my gas tank a coupel nights ago to relize that my gas mileage has dropped to 18.5 mpg and it is getting much warmer now its in the 50's.
276 miles / 14.58 gallons = not good
Anyway, I ran some vag logs to see what my lambda readings (032), coolant temp (011) and MAF (002) readings were. Problem is i have no idea what to look for or read the log! haha, ill cut and paste it and see if you guys can help me!
Tuesday,13,March,2007,16:26:30
8D0 907 559 C ,,1.8L R4/5VT MOTR AT D01,
,Group A:,'002,,,,Group B:,'011,,,,Group C:,'032
,,RPM,Time,Time,Mass Flow,,RPM,Temperature,Temperature,Ign. Timing,,Lambda,Lambda, ,
,TIME,,,,,TIME,,,,,TIME,,,,
MARKER,STAMP, /min, ms, ms, g/s,STAMP, /min,°C,°C, °BTDC,STAMP,%,%,,
,0.76,1280,0.80,0.00,3.33,1.15,1440,78.0,25.5,9.8, 0.38,-2.3,3.1, ,
,1.90,1560,5.20,11.65,26.18,2.27,1600,78.0,24.0,9. 8,1.51,-2.3,3.1, ,
,3.05,1640,6.20,12.16,32.71,3.43,1720,78.0,21.0,8. 3,2.65,-2.3,3.1, ,
,4.19,1880,6.75,13.82,40.56,4.57,1920,78.0,19.5,6. 8,3.82,-2.3,3.1, ,
,5.35,2120,7.00,14.40,47.22,5.74,2160,78.0,19.5,9. 0,4.97,-2.3,3.1, ,
,6.50,2320,6.95,14.08,51.81,6.87,2440,78.0,18.0,11 .3,6.12,-2.3,3.1, ,
,7.62,2560,6.95,14.27,57.43,8.01,2640,78.0,18.0,12 .8,7.26,-2.3,3.1, ,
,8.76,2840,7.25,14.91,64.93,9.19,2920,78.0,18.0,14 .3,8.39,-2.3,3.1, ,
,9.96,3080,7.30,14.98,72.08,10.34,3200,78.0,19.5,1 7.3,9.58,-2.3,3.1, ,
,11.13,3360,7.05,14.72,75.83,11.53,3440,78.0,19.5, 20.3,10.74,-2.3,3.1, ,
,12.31,3600,7.00,14.91,81.11,12.68,3720,78.0,21.0, 23.3,11.91,-2.3,3.1, ,
,13.43,3880,7.00,14.91,86.32,13.85,3960,78.0,21.0, 24.8,13.05,-2.3,3.1, ,
,14.62,4120,7.00,15.23,91.87,14.98,4200,78.0,21.0, 25.5,14.23,-2.3,3.1, ,
,15.75,4360,7.00,15.36,97.36,16.12,4440,78.0,22.5, 26.3,15.38,-2.3,3.1, ,
,16.87,4560,6.95,15.55,101.53,17.25,4680,78.0,24.0 ,27.0,16.50,-2.3,3.1, ,
,18.01,4800,6.95,16.00,106.32,18.37,4880,78.0,24.0 ,26.3,17.62,-2.3,3.1, ,
,19.13,5000,6.95,16.19,110.83,19.51,5080,78.0,25.5 ,26.3,18.76,-2.3,3.1, ,
,20.26,5200,6.80,16.26,113.19,20.65,5280,78.0,25.5 ,27.0,19.89,-2.3,3.1, ,
,21.40,5400,6.80,16.32,116.81,21.77,5440,78.0,25.5 ,27.0,21.01,-2.3,3.1, ,
,22.54,5560,6.75,16.32,119.23,22.93,5640,78.0,27.0 ,27.0,22.15,-2.3,3.1, ,
,23.69,5720,6.60,16.32,121.11,24.07,5760,78.0,27.0 ,27.0,23.32,-2.3,3.1, ,
,24.82,5880,6.50,16.26,122.08,25.19,5920,78.0,28.5 ,28.5,24.44,-2.3,3.1, ,
,25.97,6040,6.35,15.81,121.81,26.34,6040,78.0,28.5 ,29.3,25.57,-2.3,3.1, ,
,27.14,6160,6.25,15.62,122.36,27.53,6160,76.5,28.5 ,29.3,26.74,-2.3,3.1, ,
,28.29,6160,1.10,1.79,22.50,28.68,6080,76.5,28.5,3 7.5,27.91,-2.3,3.1, ,
,29.43,5920,0.65,1.02,12.36,29.81,5840,76.5,28.5,3 7.5,29.04,-2.3,3.1, ,
,30.56,4880,0.65,0.00,10.69,30.95,4240,76.5,28.5,3 7.5,30.20,-2.3,3.1, ,
,31.70,4000,0.55,0.00,7.15,32.10,3720,76.5,27.0,37 .5,31.33,-2.3,3.1, ,
,32.87,2880,0.55,0.00,5.34,33.24,2840,76.5,27.0,32 .3,32.48,-2.3,3.1, ,
,34.00,2800,0.45,0.00,4.31,34.37,2760,76.5,27.0,31 .5,33.62,-2.3,3.1, ,
