Mechanical cooling fan
Old 10-08-2010 | 08:13 PM
CitizenKane's Avatar
Default Mechanical cooling fan
Does anyone know how to remove this blade? I need to take the compressor out and the blade is blocking me from pulling it out.
B5A4 2.8L V6
Old 10-08-2010 | 10:22 PM
02A6Beau's Avatar
I believe that is viscous cooling fan
looks like you have the screws out already, the blade should just pop right off. If you need to remove the pulley, its a reverse threaded nut on the back (lefty tighty) and its the pulley that requires the dreaded audi chopsticks tool to hold still while you try to turn the nut. There are a couple work arounds but most are pretty sketchy. I tied mine to the frame to hold it still.
hopefully someone else will chime in here with some suggestions
Old 10-08-2010 | 10:28 PM
thanks mate, but it won't just pop off. I don't need the pulley off, and if I pull any harder I'll break the plastic blade or something else. That plastic blade is blocking the a/c compressor from coming out; it's the only thing in the way.
soccergk
10-03-2017 04:21 AM
96whitea4
06-03-2012 07:37 PM
T_REV_17
04-14-2011 04:07 PM
jgm7507
10-31-2007 07:33 PM
True_Pinoy
05-23-2006 04:47 PM
Quick Reply: Mechanical cooling fan
