Sponsored by:
Sponsored by:
MBC Installed
Old 09-27-2007, 08:08 PM
Stuntman's Avatar
Default MBC Installed
Finnaly got it in the mail. ECS tuning forge MBC. Didnt have time to take pics. (Got dark quick).
I have been out testing it for a wile. WOWOW! I love it!! It will boost to 14psi max. I have the stock DV, and thinking thats why. (Not sure tho)
I bumped it down to 12psi. She only runs a little lean 6k rpms +. geting 12.1 a/f ratio up there.
With all the mods I have CAI, straight exhaust, new NGK's, new IC, and MBC. What do you guys think im making at the wheels?
Old 09-27-2007, 08:14 PM
chaos92287's Avatar
Default RE: MBC Installed
so your purposely running lean?
Old 09-27-2007, 08:19 PM
cincyTT's Avatar
I'm make believe
12:1 is far from lean. thats about where you want it, if not leaner at 12.5:1. ALso, thats as high as that mbc will go. So whenever you want to go higher, its not going to happen.
Old 09-27-2007, 08:47 PM
Stuntman's Avatar
I have read posts about psi cut off on the forge mbc. Is this true? I was thinking it was the stock dv leting air through. And yea 12:1 isnt really lean. Just isnt ideal 12.5:1.
even at 12-14psi this car is a hole new monster. I love it!!
Old 09-27-2007, 08:48 PM
cincyTT's Avatar
I'm make believe
There is nothing wrong with that mbc, it just had limit adjustablity
Old 09-27-2007, 09:15 PM
Bondga's Avatar
no its not the stock dv stopping your boost. the stock dv starts opening at 18psi.
Old 09-27-2007, 09:20 PM
Stuntman's Avatar
Oh really? 18psi. So do you think ill be needing a new dv any time soon if im runing 12-14psi?
Also what do yea think im geting to the wheels? 180-200hp 210-220tq?
Old 09-27-2007, 09:23 PM
Bondga's Avatar
well the stock one will eventually tear so you'll have to replace it sooner or later, but i've been running 18lbs on the stock one for about 4 months
cincyTT's Avatar
I'm make believe
The stock valves can hold 25+psi. The durabilty is what makes them iffy.
Old 09-27-2007, 09:27 PM
Bondga's Avatar
i dont know i cant get over 18 psi and im using an ebc. maybe its my valve that just sucks
Quick Reply: MBC Installed
