Manual Trans oil
RE: Manual Trans oil
ORIGINAL: david9999
I can try to look it up later, but you fill it until is starts to leak out the fill hole.
*FYI: When I dumped the oil it only had 2 quarts in it?
ORIGINAL: david9999
I'd suggest investing 15 dollars in a chilton's or Haynes manual which had pretty good pictures for basic maintenance, etc
I've seen answers from 2-5? Can anyone who has a bently or similar manual look this up? []. I need to get this car out of the garage. I'm sure the 3 is fine, but I would prefer to be on the safe side (I can take a whole trans apart, yet not know how much fluid [&:])
Well I had to goto a German VW site (luckly its written in 1/2 english), but I found a lot of factory type assembly instructions. According to the factory specs it should only take 2.4Q's....
http://volkswagen.msk.ru/transmissio...2_overhaul.pdf
secmil
11-26-2007 11:25 AM
